Milter-greylist
Index last updated: 2026-04-28 23:32 UTC
RCPT information in X-Greylist: inspected by header is empty
2015-08-18 by Marcus Schopen
RCPT information in "X-Greylist: inspected by ..." header is empty:
Aug 18 13:38:47 mail sm-mta[2685]: t7IBcj35001685: Milter add: header:
X-Greylist: inspected by milter-greylist-4.5.11 (mx.server.com [x.x.x.x]);
Tue, 18 Aug 2015 13:38:47 +0200 (CEST) for IP:'x.x.x.x'
DOMAIN:'smtp.server.com' HELO:'smtp.senderserver.com'
Setup is running milter-greylist-4.5.11 with 8.14.4-4.1ubuntu1 on Ubuntu
14.04 LTS. Milter-greylist is running via TCP socket on an internal
machine.
sendmail.mc:
INPUT_MAIL_FILTER(`greylist',`S=inet:12345@scanner, F=, T=S:1m;R:1m')dnl
greylist.conf:
racl continue from /.*/ addheader "X-Greylist: inspected by %V for IP:'%i'
DOMAIN:'%d' HELO:'%h' FROM:'%f' RCPT:'%r'"
Ciao
Marcus
Re: [milter-greylist] RCPT information in X-Greylist: inspected by header is empty
2015-08-19 by Marcus Schopen
On Tue, 18 Aug 2015 14:41:25 +0000, "Emmanuel Dreyfus manu@...
[milter-greylist]" <milter-greylist@yahoogroups.com> wrote:
> On Tue, Aug 18, 2015 at 01:50:15PM +0200, Marcus Schopen
> Recipient was <> ?
No, the recipient is not <>. I'm using mimedefang's
md_check_against_smtp_server feature to check if an recipient exists on the
internal Server. But mimedefang is called after milter-greylist and
md_check_against_smtp_server does the check with an empty sender and not
with an empty recipient.
INPUT_MAIL_FILTER(`greylist',`S=inet:12345@internal, F=, T=S:1m;R:1m')dnl
INPUT_MAIL_FILTER(`mimedefang', `S=inet:123457@internal, F=T,
T=S:5m;R:5m;E:10m')dnl
INPUT_MAIL_FILTER(`opendkim',`S=inet:123458@internal, F=, T=S:1m;R:1m')dnl
Ciao!
2016-09-08 by Marcus Schopen
On 2015-08-18 13:50, Marcus Schopen lists-yahoogroups@...
> Hi,
> [x.x.x.x]);
> FROM:'sender@...' RCPT:''
> Ubuntu
> machine.
> sendmail.mc:
> T=S:1m;R:1m')dnl
> greylist.conf:
> IP:'%i'
Checking some logs this morning I'd like to come back to above problem
one year ago. I checked all hosts, where milter-greylist is running.
After upgrading to version 4.6.1 on some hosts the problem is still
there and I have an empty rcpt %r value:
mail.log:
Sep  8 08:04:14 vorlage1204 milter-greylist: u8863xiF006342: skipping
greylist because this is the default action, (from=<info@...>,
rcpt=<ich@...>, addr=[192.168.100.100][192.168.100.100]) ACL 186
Sep  8 08:04:14 vorlage1204 sm-mta[6342]: u8863xiF006342:
milter=greylist, action=rcpt, continue
Sep  8 08:04:14 vorlage1204 sm-mta[6342]: u8863xiF006342: Milter
(greylist): time command (R), 0
Sep  8 08:04:16 vorlage1204 sm-mta[6342]: u8863xiF006342:
milter=greylist, action=data, continue
Sep  8 08:04:16 vorlage1204 sm-mta[6342]: u8863xiF006342: Milter
(greylist): time command (T), 0
Sep  8 08:04:19 vorlage1204 sm-mta[6342]: u8863xiF006342:
from=<info@...>, size=6, class=0, nrcpts=1,
msgid=<201609080604.u8863xiF006342@...>, proto=ESMTP,
daemon=MTA-v4, relay=[192.168.100.100]
Sep  8 08:04:19 vorlage1204 sm-mta[6342]: u8863xiF006342: Milter
(greylist): headers, send
(greylist): headers, sent
milter=greylist, action=eoh, continue
(greylist): body, send
milter=greylist, action=body, continue
(greylist): body, sent
Sep  8 08:04:19 vorlage1204 sm-mta[6342]: u8863xiF006342: Milter add:
header: X-Greylist: Default is to whitelist mail, not delayed by
milter-greylist-4.6.1 (vorlage1204.testdom.de [192.168.100.21]); Thu, 08
Sep 2016 08:04:19 +0200 (CEST)
header: X-Greylist: inspected by milter-greylist-4.6.1
(vorlage1204.testdom.de [192.168.100.21]); Thu, 08 Sep 2016 08:04:19
+0200 (CEST) for IP:'192.168.100.100' DOMAIN:'[192.168.100.100]'
HELO:'me' FROM:'info@...' RCPT:''
Sep  8 08:04:19 vorlage1204 sm-mta[6342]: u8863xiF006342: Milter accept:
message
Sep  8 08:04:19 vorlage1204 sm-mta[6343]: u8863xiF006342:
to=<ich@...>, delay=00:00:05, xdelay=00:00:00, mailer=local,
pri=30687, dsn=2.0.0, stat=Sent
sendmail.mc:
define(`confMILTER_LOG_LEVEL', `99')dnl
INPUT_MAIL_FILTER(`greylist',`S=local:/var/run/milter-greylist/milter-greylist.sock,
This might be the reason why I can't combine a from and rcpt list in a
ACL (see yesterdays mail "combining from and rcpt lists in one ACL").
Any ideas?
Ciao
Marcus
2016-09-14 by Marcus Schopen
Hi Emmanuel,
On 2016-09-14 05:26, manu@... [milter-greylist] wrote:
> Marcus Schopen lists-yahoogroups@... [milter-greylist]
>> Any ideas?
> Do you have {rcpt_addr} in sendmail.cf O Milter.macros.envrcpt?
Thanks for your feedback. Yes, I think I do have set {rcpt_addr}:
grep Milter.macros sendmail.cf:
sendmail.cf:O Milter.macros.connect=j, _, {daemon_name}, {if_name},
{if_addr}
sendmail.cf:O Milter.macros.helo={tls_version}, {cipher}, {cipher_bits},
{cert_subject}, {cert_issuer}
sendmail.cf:O Milter.macros.envfrom=i, {auth_type}, {auth_authen},
{auth_ssf}, {auth_author}, {mail_mailer}, {mail_host}, {mail_addr}
sendmail.cf:O Milter.macros.envrcpt={rcpt_mailer}, {rcpt_host},
{rcpt_addr}
sendmail.cf:O Milter.macros.eom={msg_id}
greylist.conf:
IP:'%i' DOMAIN:'%d' HELO:'%h' FROM:'%f' RCPT:'%r'"
racl whitelist default
Logfile, with milter-greylist 4.6.1, sendmail 8.14.4-2ubuntu2.1:
Sep 14 13:23:00 vorlage1204 sm-mta[2723]: u8EBN0HL002723: Milter
(greylist): init success to negotiate
Sep 14 13:23:00 vorlage1204 sm-mta[2723]: u8EBN0HL002723: Milter:
connect to filters
Sep 14 13:23:00 vorlage1204 milter-greylist: GeoIP is not available
milter=greylist, action=connect, continue
(greylist): time command (C), 0
Sep 14 13:23:04 vorlage1204 sm-mta[2723]: u8EBN0HL002723:
milter=greylist, action=helo, continue
Sep 14 13:23:04 vorlage1204 sm-mta[2723]: u8EBN0HL002723: Milter
(greylist): time command (H), 0
Sep 14 13:23:10 vorlage1204 sm-mta[2723]: u8EBN0HL002723: Milter:
sender: <test@...>
milter=greylist, action=mail, continue
(greylist): time command (M), 0
Sep 14 13:23:19 vorlage1204 sm-mta[2723]: u8EBN0HL002723: Milter: rcpts:
<test@...>
Sep 14 13:23:19 vorlage1204 milter-greylist: u8EBN0HL002723: skipping
greylist because this is the default action, (from=<test@...>,
rcpt=<test@...>, addr=[192.168.100.100][192.168.100.100]) ACL 176
Sep 14 13:23:21 vorlage1204 sm-mta[2723]: u8EBN0HL002723:
Sep 14 13:23:21 vorlage1204 sm-mta[2723]: u8EBN0HL002723: Milter
Sep 14 13:23:27 vorlage1204 sm-mta[2723]: u8EBN0HL002723:
from=<test@...>, size=5, class=0, nrcpts=1,
msgid=<201609141123.u8EBN0HL002723@...>, proto=ESMTP,
Sep 14 13:23:27 vorlage1204 sm-mta[2723]: u8EBN0HL002723: Milter
Sep 14 13:23:27 vorlage1204 sm-mta[2723]: u8EBN0HL002723: Milter add:
milter-greylist-4.6.1 (vorlage1204.test.de [192.168.100.21]); Wed, 14
Sep 2016 13:23:27 +0200 (CEST)
(vorlage1204.test.de [192.168.100.21]); Wed, 14 Sep 2016 13:23:27 +0200
(CEST) for IP:'192.168.100.100' DOMAIN:'[192.168.100.100]' HELO:'me'
Sep 14 13:23:27 vorlage1204 sm-mta[2723]: u8EBN0HL002723: Milter accept:
message
Sep 14 13:23:27 vorlage1204 sm-mta[2724]: u8EBN0HL002723:
to=<test@...>, delay=00:00:08, xdelay=00:00:00, mailer=local,
pri=30695, dsn=2.0.0, stat=Sent
Don't understand why %r value is missing at the point of inserting the
X-Greylist header.
Ciao!
2016-09-17 by manu@...
> X-Greylist header.
I looked at the sources. The header addition happens at the DATA stage,
when there is no defined recipient because there may be multiple
recipients.
%r is only valid at RCPT-stage. I see no way of easily fixing this:
should we add multiple headers when we have multiple recipients?
Emmanuel Dreyfus
http://hcpnet.free.fr/pubz
manu@...
2016-09-17 by Marcus Schopen
>> X-Greylist header.
> recipients.
Hmmm, in the tests I just had one single rcpt.
Good question, might be helpful ...
Ciao
Marcus
> > recipients.
Sure, but this is a general problem: at DATA-stage, there is no such
concept as "the unique recipent".
Emmanuel Dreyfus
manu@...
