Milter-greylist
Index last updated: 2026-04-28 23:32 UTC
Milter-greylist with p0f ver 3.06b
2013-01-24 by Gary Faith
On Feb 15, 2012, I posted a problem with p0f v3 and subsequently a new milter-greylist 4.41a1 was built and that fixed the problem.
I had p0f 3.03b installed and working with Milter-Greylist: milter-greylist-4.4a1.  I just downloaded the latest version of p0f 3.06b, compiled it and now I am getting errors.
Jan 23 19:58:50 mscan milter-greylist: p0f rejected query
Jan 23 19:59:33 mscan milter-greylist: p0f rejected query
Jan 23 19:59:54 mscan milter-greylist: p0f rejected query
Jan 23 20:00:58 mscan milter-greylist: p0f rejected query
Jan 23 20:01:29 mscan milter-greylist: p0f rejected query
Jan 23 20:01:53 mscan milter-greylist: p0f rejected query
Jan 23 20:02:03 mscan milter-greylist: p0f rejected query
and in the /var/log/p0f.log.error:
[!] WARNING: Query with bad magic (0x1000000).
If I run 3.03b, it works.  I thought maybe that milter-greylist 4.4.1 might fix the problem so I updated to that version but still have the same issue.
What could be the problem?
Gary Faith
Re: Milter-greylist with p0f ver 3.06b
2013-01-25 by super_1337_2010
I don't know if this is exactly the same problem, but when I run milter-greylist with p0f, p0f dies with the following message, when a mail message comes through:
[!] WARNING: Query with bad magic (0xdefaced).
[-] SYSTEM ERROR : read() on API socket fails despite POLLIN.
      OS message : Connection reset by peer
I'm running p0f from the command line with:
/usr/sbin/p0f -i br0 -f /etc/p0f.fp -s /var/run/p0f.socket -u smmsp
I have tried the latest stable and unstable, and cvs versions of milter-greylist and p0f 3.03 and 3.06.  I see that there have been discussions about this in the past.
So far I'm only able to run milter-greylist-2.4.6 with p0f 2.0.8
I run 64-bit gentoo Linux.
--- In milter-greylist@yahoogroups.com, "Gary Faith"  wrote:
> As a followup, I e-mailed the author of p0f and this is what he sent back:
> Version 3.06 fixed a query structure alignment issue present in
> earlier versions of p0f v3. That may be causing problems. I'd ping the
> author of the filter. It should be a trivial change.
> If you want to temporarily "fix" your version, edit api.h for p0f 3.06
> and remove the two mentions of __attribute__((packed)). This will
> restore the old behavior.
> /mz
> I removed the two mentions of the __attribute__((packed)) and it works now but going forward can milter-greylist be updated to work with the new p0f without the change?
> Thanks,
> Gary
> >>> "Gary Faith"  1/23/2013 8:34 PM >>>
> Thanks,
> Gary Faith
Re: [milter-greylist] Milter-greylist with p0f ver 3.06b
2013-01-26 by Gary Faith
Anyone?
>>> "Gary Faith" <gafaith@...> 1/23/2013 9:07 PM >>>
/mz
Gary
>>> "Gary Faith" <gafaith@...> 1/23/2013 8:34 PM >>>
Gary Faith
2013-01-27 by super_1337_2010
> What version of milter-greylist are you trying with p0f 3.03 and 3.06?
> The solution is install milter-greylist 4.4.1 and use p0f 3.03b or greater with the exception of 3.06b.  You can use 3.06b if you modify the api.h before you build it.
> Location : live_event_loop(), p0f.c:916
Hi.
After many months I've finally fixed this.  I was using
# ./configure --enable-p0f
instead of
# ./configure --enable-p0f3
I have used version 3.06b with __attribute__((packed)) removed and it works now, with milter-greylist 4.4.1
One problem that I now have is that my logs don't always pick up the OS of the sender - this didn't happen with earlier versions of milter-greylist and p0f 2 - eg - see "()" in:
2013/01/27 14:43:21 smtpna.posta.tim.it [217.200.184.87] () tsole@... -> me@... accept (ACL 339)    Delayed for 05:18:28 by milter-greylist-4.4.1 (mydomain.com.au [192.168.0.40]); Sun, 27 Jan 2013 14:43:21 +1100 (EST)
This is the relevant line in my config:
stat ">>/var/log/milter-greylist.log" "%T{%Y/%m/%d %T} %d [%i] (%Fx) %f -> %r %S (ACL %A) %Xc %Xe %Xm %Xh\n"
Maybe this is not important - it still seems to delay messages appropriately.
I start p0f with:
# /usr/sbin/p0f -i br0 -f /etc/p0f.fp -s /var/run/p0f.socket -u smmsp -o /var/log/p0f-audit.log 'tcp and tcp[13] & 2 = 2'
Another question - I see the new version of p0f has "Windows 7 or 8".   Should this be greylisted?  Currently it is not:
## See http://milter-greylist.wikidot.com/using-p0f
# safe Windows hosts
racl whitelist p0f "Windows 2003"       addheader "X-Greylist-OS: %Fx"
racl whitelist p0f "Windows 2008"       addheader "X-Greylist-OS: %Fx"
racl whitelist p0f "Windows 2000 SP4"   addheader "X-Greylist-OS: %Fx"
# unsafe Windows hosts -- put this line below ALL racl whitelist lines
racl greylist  p0f "Windows" addheader "X-Greylist-OS: %Fx"
Re: [milter-greylist] Re: Milter-greylist with p0f ver 3.06b
2013-01-27 by manu@...
> instead of
I was just going to look at the issue. Glad to see it is already fixed
Emmanuel Dreyfus
http://hcpnet.free.fr/pubz
manu@...
Did you use configure --enable-p0f or configure --enable-p0f3 ? The
latter should work without patching anything.
Emmanuel Dreyfus
manu@...
2013-01-29 by manu@...
> So the issues isn't adding the --enable-p0f3  to the ./configure line
> because I already had it.  The issue is the change is structure in the
> p0f_api_query and p0f_api_response.
If you use --enable-p0f3, we get the 0f_api_query and p0f_api_response
through #include <api.h>. Therefore if you install a fixed p0f-3.x and
rebuild milter-greylist, you are done, and no change to milter-greylist
is required.
Emmanuel Dreyfus
manu@...
> So is your solution to remove the "fix for the query structure alignment
> issue" in the new version of p0f?
As I understand there is only an issue if you upgrade p0f without
rebuilding milter-greylist (or without installing a version that has
been built for the newer p0f). You think it is not reasonable?
Emmanuel Dreyfus
manu@...
2013-01-29 by Gary Faith
Do you have a version built for the newer p0f?  That is what I have been asking for all along.
>>> <manu@...> 1/29/13 10:05 AM >>>
2013-01-30 by manu@...
> I upgraded p0f to version 3.06b and installed milter-greylist 4.4.1.  They
> don't talk as I have explained 3 times now.
> If you don't want to fix it, fine.  I don't care.
I am willing to fix it, it's just that I failed to understand where
there is a thing to fix in milter-greylist. If --enabled-p0f3 is used,
we do not define the p0f structures in milter-greylist code, therefore I
have trouble to grasp how we could fix them.
But I am able to undertstand there is something broken with latest p0f,
I will give it a a try.
Emmanuel Dreyfus
manu@...
