Milter-greylist
Index last updated: 2026-04-28 23:32 UTC
milter-greylist 4.3.8 is available
2010-07-12 by manu@netbsd.org
Here is the latest developement snapshot
http://ftp.espci.fr/pub/milter-greylist/milter-greylist-4.3.8.tgz
MD5 (milter-greylist-4.3.8.tgz) = 0e15ef8b9a89432454fbeb11137ee943
Changes since 4.3.7:
        Fix spamd hang if message contains NULL (Enrico Scholz)
        Format string for SpamAssassin score
        Build fix for Solaris
        Send the queueid to spamd (Petar Bogdanovic)
        Close-on-exec sockets to avoid file shortage with stat (Enrico Scholz)
        Add a missing comma in X-Greylist (Kouhei Sutou)
        Look for liresolv in ${libdir} instead of /usr/lib (DUFRESNE VINCENT)
        Fix SPF on Postfix (Kouhei Sutou)
Emmanuel Dreyfus
http://hcpnet.free.fr/pubz
manu@...
2010-07-12 by R P Herrold
along the lines of auto-tools fixes, I get this with that
4.3.8 in the auto-tools as well:
config.status: creating Makefile
config.status: WARNING:  'Makefile.in' seems to ignore the --datarootdir setting
config.status: creating milter-greylist.spec
-- Russ herrold
Re: [milter-greylist] milter-greylist 4.3.8 is available
2010-07-13 by manu@netbsd.org
> setting
Hello
Will you contribute a fix?
Emmanuel Dreyfus
manu@...
2010-07-13 by R P Herrold
>> setting
sure.  per the autoconf manual, it seems to be a one liner
diff below, inline
and it now runs without that error:
[herrold@centos-5 milter-greylist]$ rpmbuild -ba \
 	milter-greylist-4.3.8.spec 2>&1 | grep datadir
+ ./configure --build=x86_64-redhat-linux-gnu
--host=x86_64-redhat-linux-gnu
--target=x86_64-redhat-linux-gnu --program-prefix=
--prefix=/usr --exec-prefix=/usr --bindir=/usr/bin
--sbindir=/usr/sbin --sysconfdir=/etc --datadir=/usr/share
--includedir=/usr/include --libdir=/usr/lib64
--libexecdir=/usr/libexec --localstatedir=/var
--sharedstatedir=/usr/com --mandir=/usr/share/man
--infodir=/usr/share/info --with-user=smmsp
-- Russ herrold
4.8.3 Changed Directory Variables
In Autoconf 2.60, the set of directory variables has changed,
and the defaults of some variables have been adjusted (see
Installation Directory Variables) to changes in the GNU Coding
Standards. Notably, datadir, infodir, and mandir are now
expressed in terms of datarootdir. If you are upgrading from
an earlier Autoconf version, you may need to adjust your files
to ensure that the directory variables are substituted
correctly (see Defining Directories), and that a definition of
datarootdir is in place. For example, in a Makefile.in, adding
      datarootdir = @datarootdir@
is usually sufficient. If you use Automake to create
Makefile.in, it will add this for you.
diff -u milter-greylist-4.3.8-ORIG/Makefile.in
milter-greylist-4.3.8/Makefile.in
--- milter-greylist-4.3.8-ORIG/Makefile.in      2010-04-12 08:04:41.000000000 -0400
+++ milter-greylist-4.3.8/Makefile.in   2010-07-12 22:58:16.000000000 -0400
@@ -33,6 +33,7 @@
  LDFLAGS=       @LDFLAGS@
  LIBS=          @LIBS@
  prefix=                @prefix@
+datarootdir=   @datarootdir@
  exec_prefix=   @exec_prefix@
  SYSCONFDIR=    @sysconfdir@
  LOCALSTATEDIR= @localstatedir@
Got it. Do we need in on the 4.2 branch too?
Emmanuel Dreyfus
manu@...
2010-07-13 by Peter Bonivart
Please check it in so it's not forgotten but I don't think there needs
to be a 4.2.7 release only for this.
/peter
4.2.5 Makefile.in backfix: was: milter-greylist 4.3.8 is available
testing
[herrold@centos-5 milter-greylist-4.2.5]$ ./configure 2>&1 | grep data
so, yes
(post patch)
--- milter-greylist-4.2.5-ORIG/Makefile.in      2010-04-14 00:41:22.000000000 -0400
+++ milter-greylist-4.2.5/Makefile.in   2010-07-13 09:07:03.000000000 -0400
@@ -33,6 +33,7 @@
  LDFLAGS=       @LDFLAGS@
  LIBS=          @LIBS@
  prefix=                @prefix@
On an unrelated matter, after solving an SMTP-AUTH issue for a
customer last night, I would also add to the default:
 	greylist.conf
example in each branch:
#	permit without delay when receiving email from a
#	locally authenticated sender
racl whitelist auth /.*/
-- Russ herrold
Re: [milter-greylist] 4.2.5 Makefile.in backfix: was: milter-greylist 4.3.8 is available
2010-07-14 by manu@netbsd.org
>       greylist.conf
I'm not confortable with changing defaults. It can break existing
setups, especially if the default has been there for years.
Emmanuel Dreyfus
manu@...
