milter-greylist 4.2beta1 is out
2009-02-10 by manu@netbsd.org
Here is milter-greylist 4.2 beta1, a beta for our next stable release:
http://ftp.espci.fr/pub/milter-greylist/milter-greylist-4.2b1.tgz
MD5 (milter-greylist-4.2b1.tgz) = 2e76e2643469ec393a15dfce9f8ff695
Changes since the last stable release (note to contributors: if your
contribution is not properly acknowledged in the Changelog, or if you did not
made it in the AUTHORS section of the man pages, please raise your voice):
4.2b1
Fix socket mode in sample config file
4.1.12
Build fix for missing STAILQ_* macros
4.1.11
Evaluate list clases in forward order (Rudy Eschauzier)
Fix crashes on regex substring matches (Rudy Eschauzier)
4.1.10
Build fix as some commits were missing
4.1.9
Workaround "peer queue overflow" bugs (Laurence Moindrot, Jean Benoit)
4.1.8
Allow regex on properties
Allow extended regex substitution
Custom headers can now be added to the message
Fix build with both SpamAssassin and SPF (Joel Bertrand)
4.1.7
Add p0f-required macros in milter-greylist.m4 (Joel Bertrand)
Fix memory leak (Constantine A. Murenin)
Add option to match exact domain instead of substrings (Rick Adams)
Make sure no message chunks is skip at Data stage ACL (Manuel Badzong)
Removes duplicate <> in SpamAssassin headers (Manuel Badzong)
Fixes a flaw in SpamAssassin initialization (Manuel Badzong)
Support SpamAssassin spf and dkim checks (Manuel Badzong)
Make sure DKIM code does not use invalid pointers
Add libspf2 support to .spec file for RPM (Joe Pruett)
Solaris build fix (Johann Klasek)
Fix memory leak in SpamAssassin code (Manuel Badzong)
Make implicit default rule at DATA stage silent (Greg Troxel)
4.1.6
Fix parse bug for "domain no" clause
Spamassassin support (Manuel Badzong)
Support for DATA-stage greylisting (Manuel Badzong)
Allow syslog facility to be configured (Joe Pruett)
Allow logging to be disabled on a per-ACL basis (Joe Pruett)
Honour $CPPFLAGS in Makefile (Greg Troxel)
p0f support
Experimental DKIM support (nobody tested it)
libspf2 support in .spec file, for RPM generation (Joe Pruett)
status support in Debian startup script (Bernhard Schneider)
4.1.5
Fix huge memory leaks in native LDAP support
4.1.4
Native LDAP support through OpenLDAP
4.1.3
Fix build of SPF code
Fix build of GeoIP code
4.1.2
Fix auth and tls clauses in ACL so that they accept regex
Update Debian startup script (Adam Katz)
Fix bogus ACL when using features not compiled in
Fix a crash when using SPF (Johann Klasek)
Fix Typos
4.1.1
Fix corruption in urlcheck parsing (Benoit Branciard)
Document what package contains libmilter
Fix error about stat in greylist.conf (Bob Smith)
Add configurable dumpfile permissions
Avoid C99 specific syntax (Greg Troxel)
Documentation fixes
Add SPF status selection to ACL
Add id string to ACL
Fix typos in documentation (Constantine A. Murenin)
Emmanuel Dreyfus
http://hcpnet.free.fr/pubz
manu@...
