Milter-greylist
Index last updated: 2026-04-28 23:32 UTC
Selective greylisting
2007-10-19 by Arjun Datta
My Setup:
2.6.20-1.2962.fc6
milter-greylist-3.0-1
milter-greylist-debuginfo-3.0-1
sendmail-8.13.8-2
I have noticed that my milter-greylist seems to on occasion selectively greylist senders.
For example:
My domain is xyz.com and has 2 users user1 and user2.
If sender@... sends an email addressed to both user1@... and user2@xyz.com and both tuples are not whitelisted, the first time milter-greylist will tell the sending server to try again later as greylisting is in progress.
The second time the sending server tries to send the email, milter-greylist will let the email through to user1 and autowhitelist the tuple but will greylist user2 again.
I've checked that the sending server has the same IP on all three occasions.
Arjun Datta
Re: [milter-greylist] Selective greylisting
2007-10-20 by manu@netbsd.org
> greylist senders.
> For example:
> user2@... and both tuples are not whitelisted, the first time
Could you check that this behavior also occur with 4.0rc2? Just in case
the bug you see has already been fixed?
The upgrade path is really straightforward: your config file and
greylist database should keep working as they did in 3.0.x
Emmanuel Dreyfus
http://hcpnet.free.fr/pubz
manu@...
> http://ftp.espci.fr/pub/milter-greylist/ has no such version?
Um, right, it's 4.0rc1. I'll make rc2 soon, I just need to add a sample
config file with all the fancy new features. (contributions are welcome)
Emmanuel Dreyfus
manu@...
RE: [milter-greylist] Selective greylisting
2007-10-22 by Arjun Datta
Thank you.
At the risk of sounding silly - how do I upgrade ?  Do I download the latest
tar.gz from the milter-greylist site or do just run yum upgrade
milter-greylist ?
I ask because when I installed this I had to construct an rpm for my system
from ther tar.gz using rpmbuild and then install it using rpm
-Uvh.
Arjun Datta
[mailto:milter-greylist@yahoogroups.com]On Behalf Of manu@...
Sent: Saturday, October 20, 2007 1:25 PM
To: milter-greylist@yahoogroups.com
Subject: Re: [milter-greylist] Selective greylisting
  Emmanuel Dreyfus
  manu@...
2007-10-22 by Emmanuel Dreyfus
> milter-greylist ?
> -Uvh.
I don't know about the packages that come with your distribution, but
as fas as milter-greylist is concerned, you upgrade by just replacing the
binary and restarting the milter.
Make sure you supplied the same --with-user options to configure, or you'll
might have to tweak permissions.
Emmanuel Dreyfus
manu@...
2007-10-22 by Nerijus Baliunas
> milter-greylist ?
It's up to you how do you upgrade - you can use tar.gz or yum update,
if you have yum repository set up which has milter-greylist package.
That's a good option.
Emmanuel, do you think it's worth moving section 16 "Packaging" after
the 1st section (and probably making it a subsection)?
Nerijus
Well, I'd rather add a reference to section 16 in section 1. What do you
think?
Emmanuel Dreyfus
manu@...
2007-10-22 by Michael Mansour
> > milter-greylist ?
Dries (of rpmforge) has kindly provided the RPM support of milter-greylist, so
you'll find it in the rpmforge repositories.
As a general rule, rpmforge don't provide beta's of any packages, so when the
latest milter-greylist goes stable, I'm sure either him or Dag will provide
the RPM for that release too.
Michael.
> think?
It's OK too.
Nerijus
