Milter-greylist
Index last updated: 2026-04-28 23:32 UTC
Help!
Help!
2006-10-27 by An.H.Nguyen
Both of my Solaris sendmail gateways started to have some problems since Oct.14 when the "Possible SMTP attack: command=HELO/EHLO, count=3" appeared.
- Sendmail stops repsonding for a short time then came back, this happens several times a day
- milter-greylist process died, then it came back on by itself in about 5 minutes, this also happens serveral times a day
- I can't fine /var/milter-greylist/milter-greylist.sock on one of my two servers, should I copy this file over? (It's size is zero and has a special permission settings srwxr-xr-x)
Some error messages (random picks, not in any orders):
milter-greylist: [ID 552762 mail.error] greylist: accept() returned invalid socket (Too many open files)
milter-greylist: [ID 879519 mail.warning] greylist: setsockopt() failed
Milter (greylist): timeout before data read
Milter (greylist): init failed to open
Milter (greylist): error connecting to filter: Connection refused by /var/milter-greylist/milter-greylist.sock
mimedefang-multiplexor[12219]: [ID 260045 mail.error] Reap: Idle slave 9 (pid 25739) exited normally with status 255 (SLAVE DIED UNEXPECTEDLY)
mimedefang-multiplexor[12219]: [ID 389462 mail.error] Slave 6 died prematurely -- check your filter rules
mimedefang[12232]: [ID 847421 mail.error] Error from multiplexor: ERR No response from slave
mimedefang[27731]: [ID 758488 mail.warning] mfconnect: Error communicating with multiplexor
mimedefang-multiplexor[27727]: [ID 980602 mail.info] Slave 5 stderr: getservbyname failed for tcp at /usr/local/bin/mimedefang.pl line 529
; sendmail[18155]: [ID 801593 mail.warning] k9RFFCUM018155: collect: premature EOM: unexpected close
sendmail[26774]: [ID 801593 mail.info] k9RHumxI026774: Milter (greylist): to error state
SW Versions:
Sendmail 8.12.10
mimedefang version 2.51
SpamAssassin version 3.0.3
running on Perl version 5.8.0
milter-greylist: I'm not sure what version it is, help!..
I'm new to this environment, I take over from a previous sysadmin who left so I am desperate here...
I think about upgrading, but affraid to break things up. I have clone one of the gateways to a 3rd server and able to do testings on it.
Please help!
An Nguyen
Re: [milter-greylist] Help!
2006-10-27 by Oliver Fromme
No.  You cannot copy a socket.  Sockets are special files
that are autmatically created when a server process binds
to a UNIX domain socket.  Restarting the server process
(in this case, milter-greylist) should be sufficient to
create the socket.
 > SW Versions:
 > Sendmail 8.12.10
You should upgrade ASAP.
Best regards
   Oliver
Oliver Fromme,  secnetix GmbH & Co. KG, Marktplatz 29, 85567 Grafing
Dienstleistungen mit Schwerpunkt FreeBSD: http://www.secnetix.de/bsd
Any opinions expressed in this message may be personal to the author
and may not necessarily reflect the opinions of secnetix in any way.
"The ITU has offered the IETF formal alignment with its
corresponding technology, Penguins, but that won't fly."
        -- RFC 2549
2006-10-27 by eclark
We run 81211 with the patches. But anyway! If you are getting flooded to the
point where for some unknown reason greylist goes down, you can use a cronjob
like so:
*/10 * * * * /home/gdmilter/is-milter-alive.sh >/dev/null 2>&1
#!/bin/bash
pids=($(pgrep gdmilter))
if (( ${#pids[@]} > 3 ))
then
 echo "`date` up with ${#pids[@]}" >> /home/gdmilter/gdmilterlog
else
  echo down with ${#pids[@]} at $(date) >> /home/gdmilter/gdmilterlog
  rm -rf /home/gdmilter/milter-gdmilter.sock
  /etc/rc.d/init.d/gdmilter stop
  killall -9 gdmilter ; kill -9 $(pidof gdmilter)
  sleep 5; kill -9 `pidof gdmilter`
  /etc/rc.d/init.d/gdmilter start
  echo $(date) restarted >> /home/gdmilter/gdmilterlog
fi
Obviously we renamed the milter to gdmilter, and stuck the socket elsewhere,
but you get the general idea. This will help get the milter back up if it
gets overloaded to the point where it shuts down.
> create the socket.
>  > SW Versions:
>  > Sendmail 8.12.10
> Best regards
>    Oliver
2006-10-27 by Bigby Findrake
> appeared.
No, you should not copy it over.  It's a socket (hence the leading "s" in
the permissions) and even if you could find a way to copy it, it wouldn't
be connected to the milter-greylist process in a meaningful way.
Stop and re-start the milter-greylst daemon/process to recreate the
socket.
You need to find out if the number of files open is reasonable for your
system load, and if so, increase the MAXFILES for the system, or find out
what has gone wrong so that MAXFILES has been reached.
Help with that is somewhat outside of the scope of this mailing list, I
would guess.
> SW Versions:
> Sendmail 8.12.10
I believe you can run "milter-greylist -r" to get its version.
> left so I am desperate here... I think about upgrading, but affraid to
> able to do testings on it. Please help! An Nguyen
		"A witty saying proves nothing."
				-- Voltaire
finger://bigby@...
http://www.ephemeron.org/~bigby/
irc://irc.ephemeron.org/#the_pub
news://news.ephemeron.org/alt.lemurs
2006-10-27 by George Elgin
i have noticed some cases where if milter crashes .sock file still exists
and must manually be removed before milter will come up correctly. perhaps
code should do an unlink(2) before trying to bind ?
> > create the socket.
Do You Yahoo!?
http://mail.yahoo.com
My greylist version is milter-greylist-1.6
It looks like this is a single file program. What do I need to do If I want to upgrade it?
An Nguyen
Sent: Friday, October 27, 2006 12:27 PM
Subject: Re: [milter-greylist] Help!
> appeared.
socket.
would guess.
> SW Versions:
> Sendmail 8.12.10
>; running on Perl version 5.8.0
-- Voltaire
finger://bigby@home.ephemeron.org
2006-10-27 by manu@netbsd.org
> want to upgrade it?
Download the latest tarball, build it and replace the milter-greylist
binary.
Emmanuel Dreyfus
http://hcpnet.free.fr/pubz
manu@...
