IAP
2006-05-28 by a_storic
Is it possible to program the LPC2129 micro for RTOS operation and then reprogram a task within the micro RTOS for a new function. IE program the micro to be a particular function type (set the input and output pins, comms Ethernet, CAN, the number of task(program parameters for how the input and output will function) and then with the IAP program task with the program. having allocated task at particular memory location within the micro then by writing a small code compiled to then be loaded into the micro as a defined task within the existing micro program. ANdrew
