Lpc2000
Index last updated: 2026-04-28 23:31 UTC
Anybody implement NAND flash driver on LPC210x ?
2004-04-01 by berrycake33
Has anybody implemented NAND flash driver on LPC210x ?
Now we are considering using LPC2106 in our project which needs
a NAND flash to storage data.
Two UARTs, I2C and SPI are all used for other functions.
If p0.23 to p0.31 is used for NAND flash data pins, it will occupy
the pins for JTAG2, so that we can't use JTAG to debug anymore.
Any idea on it ?
Shinn
Re: [lpc2000] Anybody implement NAND flash driver on LPC210x ?
2004-04-01 by Alaric B Snell
Why is the I2C and SPI all used up? Do you really have the entire I2C
address space used up? Why can't you spare one of the GPIO lines as an
SPI chip select and have an SPI flash?
> Shinn
ABS
Re: Anybody implement NAND flash driver on LPC210x ?
2004-04-02 by embeddedjanitor
I2C
an
SPI gives up to about 128kbytes in a single chip. With NAND flash you
can get up to 256MBytes in a single chip.
Also, NAND write speed is far faster.
-- Charles
2004-04-02 by Charles Manning
> Any idea on it ?
> Shinn
To implemt a NAND interface you will need more than just the 8 data pins, you
will also need:
CLE, ALE, CE, RE and WE.
You can probably ignore the R/B line and jsut read back status.
Assuming you are not using SPI at the same time as the NAND, youcould
potentially multiplex the SPPI data pins with two NAND pins and save two pins.
NAND is pretty fun stuff. I suggest you go read stuff about NAND on the linux
mtd and YAFFS www.
-- CHarles
Re: [lpc2000] Re: Anybody implement NAND flash driver on LPC210x ?
2004-04-02 by microbit
> I2C
> an
On Atmel's DataFlash you get up to like 8 Mbytes in a SPI device, and also
with a
handy dual RAM cache.
The need to write sectors sequentially for levelling is a pain though.
2004-04-02 by berrycake33
--- In lpc2000@yahoogroups.com, Charles Manning <manningc2@a...>
pins, you
> will also need:
youcould
save two pins.
the linux
> mtd and YAFFS www.
> -- CHarles
We had considered NAND control pins,
they are posited on the rest pins.
For easy implementing the NAND flash driver,
we'd like to put NAND data pins in a byte alignment.
That would save some instructions, although the Philips Set-Clear
GPIO operation already costs more instructions to implement data I/O.
( anybody know that why Philips uses this kind of GPIO operation
instead of direct setting 0 or 1 ? )
As for I2C and SPI, we use I2C for LCD and SPI for SD Card.
Besides, we need to transfer data from NAND to SD Card.
2004-04-02 by Alaric B Snell
Are there really no large NAND flash chips with an SPI interface? I've
seen SPI Flash with megabytes on, Atmel do a range of such chips.
> -- Charles
ABS
2004-04-02 by Robert Adsett
The obvious reason for doing this is to avoid conflicts from multiple
process (or interrupts).  Other wise you have to maintain shadow copies of
the outputs and (in an interrupt protected piece of code) update the shadow
and then the output.  In psuedo code something like:
disable_interrupts()
shadow_output = shadow_output & ~PERIPH_MASK    -- zero area to be updated
shadow_output = shadow_output | (new_value & PERIPH_MASK)       -- update
with new value
actual_output = shadow_output;
enable_interrupts()
Some other micros provide similar facilities.  The ST10 uses a construct
where a single register affects the I/O bit but maps two bit in the
register to each output, one bit patter set the output, a second clears the
output and the other two cause no effect.  It's also used on internal
registers to avoid race conditions on bits that may be affected by both the
peripheral HW and SW.
Finally note the writeup on the IOPIN register in the user manual "Note:
for test purposes, writing to this register stores the value in the output
register, bypassing the need to use both the IOSET
and IOCLR registers. This feature is of little or no use in an application
because it is not possible to write to individual bytes in
this register."
Robert
" 'Freedom' has no meaning of itself.  There are always restrictions,
be they legal, genetic, or physical.  If you don't believe me, try to
chew a radio signal. "
                         Kelvin Throop, III
2004-04-04 by Charles Manning
Byte alignment is not really a big issue. When you read/write the GPIO all
this costs extra is an extra shift (which is a cheap operation - free in many
cases on ARM).
You do however want your pins to be consecutive if possible (ie D0=P0.n...
D7=P0.n+7)
This is one of the first things that really seemed stupid the firt time I
looked at a micro that had set/clear registers. However it is actually very
efficient for cases where a register is used from multiple threads of
execution (eg. main loop and an interrupt service routine).
With set/clear, you just go ahead and set or clear pins. If you did not have
this you'd need to use a shadow register and disable/enable interrupts which
gets far more costly.
OK, I'll bite.
Since you have to support SD card anyway, why not just use a second SD card
instead of the NAND?
-- Charles
> > I2C
> > an
> with a
NAND gives you up to 256MBytes in a single chip and is faster.
-- CHarles
2004-04-04 by Lewin A.R.W. Edwards
He probably wants to support SSFDC given the description of the rest of
his project.
-- Lewin A.R.W. Edwards (http://www.zws.com/)
Learn how to develop high-end embedded systems on a tight budget!
http://www.amazon.com/exec/obidos/ASIN/0750676094/zws-20
2004-04-06 by berrycake33
--- In lpc2000@yahoogroups.com, Robert Adsett <subscriptions@a...>
multiple
copies of
the shadow
updated
update
> with new value
> enable_interrupts()
construct
clears the
internal
both the
manual "Note:
output
application
> this register."
> Robert
Thanks, Robert !
You dispel my doubts.
2004-04-07 by berrycake33
SD card
> -- Charles
Charles,
Your explanation benefits me as well.
Thanks !!
Considering the cost and size,
we perfer to use NAND flash as built-in memory.
SD card is for external large storage use.
2004-04-07 by janek_szymanski
--- In lpc2000@yahoogroups.com, "berrycake33" <berrycake33@y...>
second
> SD card
> > -- Charles
> Charles,
> Thanks !!
What capacity and speed exactly do you need?
Try serial flash (SPI) from ST like M25P40-4Mbit/25MHz/SO8 or bigger
(And you can have a number of devices on SPI bus)
2004-04-08 by janek_szymanski
second
> SD card
> > -- Charles
> Charles,
> Thanks !!
if you insist to use NAND see
http://www.xilinx.com/bvdocs/appnotes/xapp354.pdf
Much easier would be to use SPI interface and for example
serial flash like M25P40 from ST (4Mbit/25MHz/8SO)
There is nothing wrong in using SD card for internal storage either.
