CRP (Code Read Protection) investigation by stepping through the boot loader
2006-04-22 by John Heenan
This posting reports results of a quick investigation into the boot loader and CRP (Code Read Protection). It will enable you to confirm a factual error by another person asserting supposed evidence to contradict claims by Philips. The supposed evidence is not even worthy of the label circumstantial evidence. It is a trivial exercise to step through the boot loader with a debugger, but only of course after booting is complete. It is not necessary to write or adapt code to dump the bootloader, it is far easier to simply step through the bootloader using trivial techniques below, which I would have thought would have been worthy of mention by anyone with an interest in the bootloader. As to the question can you look at the bootloader, certainly you can. It is like asking can you look at a naked a woman, yes if you have eyes. As to the question can you make independent use or publish in detail what the bootloader does, that is a legal question I am unable to answer. I have a commercial interest in ensuring my code is not stolen, hence I am keen to determine if there is any basis for reasonable doubt of the claims made by Philips with regard to CRP. I decided to conduct my quick investigation using tools on hand after reading through another bizarre posting announcing web site updates concerned with the boot loader and noticing that the updates failed to include possible credible explanations I have made that answers a question that is posed in the site. This is really irritating and not worthy of resources provided by a publicly funded educational institution (see below). I have discovered a factual error on the web site also. The web site falsely claims the 'first thing' the LPC2148 bootloader does is to disable the JTAG debug port. The claim is false because the boot loader does two 'other things' first. The 'third thing' is to assign 0 to VPB register PINSEL2, which simply enables port 1 pins solely for GPIO use and cuts off access to JTAG debug and to trace. I will pose a question, why make false claims? The web site domain address used is set aside for a university level Australian educational institution publicly funded by tax payers. How disappointing. The tools I have on hand are a JTAGjet-ARM with its Chameleon debugger and an LPC2148 microcontroller. A cheap parallel port debugger with GDB would also work. I suspect IAR, Keil and Rowley toolsets can also be used. The LPC2148 user manual informs us the LPC2128 bootloader is 12K long and starts at address 0x7FFF D000, although it is remapped. So after booting I halted the device, looked at an ARM code disassembly at this address, assigned the PC to this address and started stepping. There is no reason to assume this is not the remapped start address. The first three ARM instructions assign 2 to VPB register MAMCR. The next two ARM instructions assign 3 to VPB register MAMTIM. The next three instructions assign 0 to PINSEL2 using a SWP command and stores the prior value of PINSEL2 in R0 It is trivial to skip over the SWP command to avoid becoming disconnected from the JTAG. The next two instructions swaps 0 with the contents of undocumented VPB register 0xE002 C03C into R1. The first three bits of the old contents of PINSEL2 in R0 are cleared when copying into R3 and R3 is stored back into PINSEL2. This instruction can also be stepped over to avoid disconnecting the JTAG port. The next instruction jumps to address 0x00FF D1C0, which due to remapping probably refers to address 0x0007 D1C0. Instructions following read the contents of flash memory address 0x1FC and store it to the read only register (as documented) CSPR (Code Security Protection Register) with one exception. If the contents of the memory address 0x1FC were 0x43128765 then 0x87654321 is stored instead. Hence for the LPC2148 there are at least two valid code read protection values: 0x87654321 and 0x43218765. I did not investigate any further, there is no need. The content of R0 and R1 have been retained up until I stopped investigating. There is nothing in any of this sequence that justifies reasonable doubt about Philips claims. My own explanations I expressed previously still stacks up as possible, namely that if CRP is enabled then some possible GPIO pins will not be disabled due to pin P1.26 being kept low during a reset. In addition just because JTAG may potentially get a few cycles before disconnection does not mean an internal debug signal JTAG may be asserting will be allowed to act, since a write to the CSPR would determine if internal debug signals are allowed to act. It is worth noting that each non sequential bus access adds an extra wait state and that if the access involves the VPB then an additional three wait states appears to be required. While I could find out how many cycles are required to make JTAG attempt to assert an internal debug signal, I know is not a trivially small amount. For the LPC2xxxx series only one JTAG cycle is allowed for six processor clock cycles. Number of cycles required can be assessed from examining open source JTAG code. Open source JTAG code has its origins in code written by R Longo in 2000 for an Atmel ARM processor. Atmel also has JTAG code (under NDA), which it is possible to view without signing an NDA. Even if there was no disablement of an internal debug bus signal pending writing to CSPR, it is possible there are simply not enough clock cycles avaialble to assert an internal debug signal. I really don't have time for this. I simply decided to conducted a small investigation to check out for myself. It is not worthy to discredit claims by Philips using the supposed evidence provided. In addition claims that the supposed evidence is the 'first thing' done is false. In addition claims about stack overruns etc in the bootloader are irrelevant as all such claims involve using the bootloader outside the published specifications. Also there is little part of the bootloader specification which states it is designed to have data interpreted in human readable form, so why make bizarre snide commments about the format of information? John Heenan
