Lpc2000
Index last updated: 2026-04-28 23:31 UTC
[lpc2000] CrossWorks UART example
2004-02-21 by gokbektas
It works fine, but if I close serial port and re-connect with PC without
making anything on LPC, weird data appears at PC.
If I reset LPC, it turns to normal.
It happens with CrossWorks terminal window and my own serial
port monitor software 'common'.
Any opinion?
----- \ufffdzg\ufffdn \ufffdleti -----
Kimden : lpc2000@yahoogroups.com
Kime : lpc2000@yahoogroups.com
G\ufffdnderme tarihi : 21/02/2004 13:18
Konu : [lpc2000] Res:LPC2106 Programming - ISP - Solved
I retouched with the soldering iron to pins of baby, compare function or ISP utility confirms chip is programmed.
Leon, your code sent garbage characters at 9600 baud, I tried other baud rates also...
Then I recompiled uart example of crossworks then loaded to chip...
It is working! Now, I can play ;-)
Thanks a lot! I'll upload my board's picture to my personal website soon.
G\ufffdnderme tarihi : 21/02/2004 12:57
Konu : Re: Re: [lpc2000] LPC2106 Programming - ISP and hex file
To: <lpc2000@yahoogroups.com>
Sent: Saturday, February 21, 2004 10:18 AM
Subject: Ynt: Re: [lpc2000] LPC2106 Programming - ISP and hex file
> Thanks leon,
> I tried the hex file that you sent me.
> I read 4293984050 part ID and 1.3 bootloader ID, when I click Upload to
Flash, it
> does not give any error messages, a progress bar shows it is uploading.
> When I click Compere Flash, a progress bar shows it is reading but "File
compare Fail"
> message appears at the end.
> And there is no data coming from chip when I check it with terminal
window...
It looks like you have a problem with the flash memory. I'd replace the
chip, or try another board if you have one. I'm actually using a '2104, but
it shouldn't make any difference.
Leon
Yahoo! Groups Links
<*> To visit your group on the web, go to:
     http://groups.yahoo.com/group/lpc2000/
<*> To unsubscribe from this group, send an email to:
     lpc2000-unsubscribe@yahoogroups.com
<*> Your use of Yahoo! Groups is subject to:
RE: [lpc2000] CrossWorks UART example
2004-02-21 by Paul Curtis
I assume that the serial data is being sent at full rate, so it appears
as a synchronous stream.  In this case, with no pauses, it's possible
for the UART to sync to a non-start/stop bit.  If you send your data in
bursts, you'll see possible some garbage data, and then the UART syncs
when it sees the stop and start bits with a bit of a breather in
between.
-- Paul.
Sent: 21 February 2004 19:11
To: lpc2000@yahoogroups.com
Subject: [lpc2000] CrossWorks UART example
Any opinion?
----- Özgün İleti -----
Gönderme tarihi : 21/02/2004 13:18
rates also...
soon.
Gönderme tarihi : 21/02/2004 12:57
<http://webmail.mynet.com/webmail/src/compose.php?send_to=gokbektas%40my
net.com&unique_id=2fa744d63c8fb6e397f540fb7ed4a88f> >
To: < lpc2000@yahoogroups.com
<http://webmail.mynet.com/webmail/src/compose.php?send_to=lpc2000%40yaho
ogroups.com&unique_id=2fa744d63c8fb6e397f540fb7ed4a88f> >
> Thanks leon,
to
Flash, it
uploading.
"File
compare Fail"
window...
but
Leon
Yahoo! Groups Links
<http://groups.yahoo.com/group/lpc2000/>
<http://webmail.mynet.com/webmail/src/compose.php?send_to=lpc2000-unsubs
cribe%40yahoogroups.com&unique_id=2fa744d63c8fb6e397f540fb7ed4a88f>
<http://docs.yahoo.com/info/terms/>
Yahoo! Groups Sponsor
ADVERTISEMENT
Click HereClick Here
<http://us.adserver.yahoo.com/l?M=274551.4550177.5761904.1261774/D=egrou
pweb/S=:HM/A=2019528/rand=234930562>
  _____
Yahoo! Groups Links
*	To visit your group on the web, go to:
*	To unsubscribe from this group, send an email to:
<mailto:lpc2000-unsubscribe@yahoogroups.com?subject=Unsubscribe>
*	Your use of Yahoo! Groups is subject to the Yahoo! Terms of
Service <http://docs.yahoo.com/info/terms/> .
Re: [lpc2000] CrossWorks UART example
2004-02-21 by microbit
Paul's right.
What he means is that if you start up your terminal SW while the
serial data is being output from the LPC, it will interpret the first
high-> low transition on its RXD line as a start bit.
If the data being transmitted from the LPC doesn't have a pause
between stop bit and the next start bit, the UART in your PC won't
synchronise properly.
To "fall in" the datastream, the transmitted data must have at least 9
High bits, so the PC's UART can flush out its receive shift register,
and sync properly.
-- Kris
Sent: Sunday, February 22, 2004 7:59 AM
Subject: RE: [lpc2000] CrossWorks UART example
between.
-- Paul.
Any opinion?
rates also...
soon.
> Thanks leon,
to
Flash, it
uploading.
"File
compare Fail"
window...
but
Leon
Yahoo! Groups Links
ADVERTISEMENT
  _____
Yahoo! Groups Links
Yahoo! Groups Links
