Lpc2000
Index last updated: 2026-04-28 23:31 UTC
Mixing assembly and C...
2004-02-20 by Musharraf Hanif
Hello all,
I am using Keil with a GNU compiler in an attempt to develop some code.
I have been trying to determine some method by which I can obtain the value
of the addresses of some lables (in assembly) to use them in my C code. Can
anyone help me?
Also, how can I use some constants defined in some c/h file in an assembly
file. Similarly for a reversed situation.
Any help will be appreciated.
Musharraf Hanif
Tired of spam? Get advanced junk mail protection with MSN 8.
http://join.msn.com/?page=features/junkmail
Re: Mixing assembly and C...
2004-02-21 by entell0
I am not 100% sure about how GNU compiler and assembler handle
things, but in general, if you don't mind using global variables,
then you can declare them in your C environment and reference them in
your assembly code. This will allow you to access these global
variables from both worlds.
Alternatively, if you are going to use local variables instead of
global ones, you can call your assembly routine from your C code and
pass the local variables through the function arguments. If you pass
the variables by reference, you should be able to modify their values
as well which would allow you to copy the values of your labels in
the assembly world into these arguments and pass them back to the C
world.
Lastly, if you are planning to use inline assembly, I am afraid
I am not too sure what you can and can't do. You might be able
to just put the name of the variable with an underscore in front
of it in your inline assembly code and access it that way.
Hope this helps a little.
Emrah
--- In lpc2000@yahoogroups.com, "Musharraf Hanif"
<musharraf_hanif@h...> wrote:
> Hello all,
code.
the value
code. Can
> anyone help me?
assembly
> Regards,
> Musharraf Hanif
RE: [lpc2000] Re: Mixing assembly and C...
2004-02-21 by Musharraf Hanif
What I am really trying to do is to setup vectored IRQs.
I am using assembly interrupt wrappers for ISRs in C. I want to write the
function for setting up the VIC in C. Hence I need to know the starting
address of my assembly wrappers in C. If I write the setup code for the VIC
in assembly, then there is no problem as I can use the lables.
On a slightly different note, i have a few definitions (.equ) in the
startup.s file. Is it possible to access their values in C? or if i shift
these definitions to a .h file (#define), can I use them in assembly?
Are there any other forums are there where I might find people who might be
able to help me?
Musharraf
>From: "entell0" <ediril@...>
>Reply-To: lpc2000@yahoogroups.com
>Subject: [lpc2000] Re: Mixing assembly and C...
>Date: Sat, 21 Feb 2004 05:02:09 -0000
>world.
>Emrah
> > Hello all,
>code.
>the value
>code. Can
> > anyone help me?
>assembly
> > Regards,
> > Musharraf Hanif
MSN 8 helps eliminate e-mail viruses. Get 2 months FREE*.
http://join.msn.com/?page=features/virus
Re: [lpc2000] Re: Mixing assembly and C...
2004-02-21 by capiman@t-online.de
I can't tell you exactly how it is with GNU ARM compiler / assembler.
But in VC under Windows, the C names are expanded with an additional "_" in
Assembler.
e.g.
C Funktion "test" gets "_test" in Assembler.
Alternativly you can use something like
PUBLIC C test
Don't know if this is equal in GNU / ARM environment
Perhaps it helps...
         Martin
To: <lpc2000@yahoogroups.com>
Sent: Saturday, February 21, 2004 9:15 AM
Subject: RE: [lpc2000] Re: Mixing assembly and C...
VIC
be
> able to help me?
> Regards,
> Musharraf
> >world.
> >Emrah
> > > Hello all,
> >code.
> >the value
> >code. Can
> > > anyone help me?
> >assembly
> > > Regards,
> > > Musharraf Hanif
2004-02-21 by Robert Adsett
You want to do something like this ?
void Startup( void)
  SetupVICentry( InterruptRoutine, InterruptEntry);
Where InterruptRoutine is your wrapper.  And SetupVICentry uses the
routine's address to do whatever setup it needs?
Just declare your wrapper InterruptRoutine as global in the assembly with
.global.
By far the easiest way to to figure out the C to asm interface is to 1)
read the calling standard (it's on ARM's website) and 2) generate asm from
sample C to walk through how that works in actual practice.
gas has the option of using the C preprocessor I believe.
Robert
" 'Freedom' has no meaning of itself.  There are always restrictions,
be they legal, genetic, or physical.  If you don't believe me, try to
chew a radio signal. "
                         Kelvin Throop, III
