ok; so single (D)CF, post VCAs. eg, mix pre-filter.then, i guess,
another vca to set output level?
in synthedit, it made sense to share a filter to save cpu on a
recent project, but that was pre vca/pan and mix/level.
interested you say there 8 oscillators, whereas i was suspecting
a single osc, with freq/dividing to produce divisions/harmonics.
so this could suggest independent outputs and operation? detuning?
i find the detuning a bit unimpressive, tbh, just semi's, whereas
somethign finer could really fatten things up a bit. and phasemod
and stuff like that...
hey, i haven't seen/used my ex800 (poly1) for some time, so i forget
a bit. wdf, it has it's own character, within what it has.
i'll look for the stuff you mention, but would like something
'from the horse's mouth', eg this group of interested users,
from the circuit-bending viewpoint, for purpose of discussion.
(i ain't going in there messing things up)
my main reference atm is synthedit, which has allowed me to
experiment with things like phase etc. just means i can plug
things in without breaking anything...
--- In korgpolyex@yahoogroups.com, Paul Cunningham <paul@...> wrote:
> the main difference with the Poly-800 series as opposed to other polysynths of the era is that all eight oscillators are first routed through their own amplifier, and then through a *shared* 4-pole filter. this makes it a unique instrument to play harmonically -- something between a polysynth and a monosynth. all of the other synths you mentioned use the more traditional polysynth architecture which provides each voice it's own filter and amplifier, with the filter before the amplifier. -pc
> On Feb 14, 2011, at 3:44 PM, k9k9dog wrote:
> > wondering what a block diagram of this synth
> > would look like. as in, a kind of signal flow
> > diagram or something like that.
> > just wondering about theoretical possibilities
> > (and impossibilities) for future ideas;
> > for instance, taking separate harmonics and
> > rerouting them, ringmod options, stuff like that?
> > i'd like to know more about what's going on inside,
> > how it compares,say, to juno's jp's and jx's. some
> > kind of assessment/description of the osc+filter etc.
> > circuitry.
