Archive for korgpolyex.
OT - 303
OT - 303
2008-11-15 by Atom Smasher
off topic, but since we've been talking about the TB-303, the wikipedia
page is entertaining - http://en.wikipedia.org/wiki/Roland_TB-303
make sure to check out this section -
http://en.wikipedia.org/wiki/Roland_TB-303#External_links
some of those links are totally nuts, like bach & mozart on a 303.
hopefully they'll be of use in taking the hawk-800 "to the next level".
...atom
________________________
http://atom.smasher.org/
"If the world were merely seductive, that would be easy.
If it were merely challenging, that would be no problem.
But I arise in the morning torn between a desire to
improve the world, and a desire to enjoy the world. This
makes it hard to plan the day."
-- E.B. White
Re: [korgpolyex] OT - 303
2008-11-15 by David Mochen
Hi Mike, I've been checking the completed features in the Hawk 800 site and am not sure about this:
Can the LFOs be applied on a "per DCO" basis? Say, for instance, I want to apply one specific LFO speed, depth, delay to just one of the DCOs, NOT the two DCOs at the same time, or apply wildly different LFO settings for each DCO on an independent basis. Please enlighten me, since I'm really planning to order the Hawk and aTomaHawk kits.
And, about the arp vs. sequencer debate: I'm all for the arp. And a way to control DCO pitch with EG3 or EG4 , when available, not to mention velocity sensitivity...
Judging from the latest audio clips I can envision LOTS of potential in our Korgs.
thanks!
Dave
Sent: Saturday, November 15, 2008 3:38 AM
Subject: [korgpolyex] OT - 303
page is entertaining - http://en.wikipedia .org/wiki/ Roland_TB- 303
http://en.wikipedia .org/wiki/ Roland_TB- 303#External_ links
...atom
____________ _________ ___
http://atom. smasher.org/
-- E.B. White
ARP, DCO and EG3
2008-11-15 by korgpolyex800
HI Dave,
no, the DCO's are operating using one master clock so you can't
modulate DCO1 separate from DCO2. Sorry about that.
The HAWK-800 already allows you to apply EG3 (and 4 when I implement
it) to the DCO pitch. I must do a demo of that as it's very nice indeed.
The ARP stays on the priority list.
Mike
in our Korgs.
> thanks!
> Dave
> From: Atom Smasher
> To: korgpolyex@yahoogroups.com
wikipedia
level".
> ...atom
> -- E.B. White
Re: [korgpolyex] ARP, DCO and EG3
2008-11-15 by Alex Drinkwater
On 15 Nov 2008, at 18:48, David Mochen wrote:
Hi there Mike!
Thanks for your reply. Glad to hear that DCO pitch can be controlled by EG3. Now the question is... hard-wired to both DCO's, or can the EG3 > pitch can be applied selectively on one of the DCOs?
I imagine the answer to that one is also 'no'. Since both oscillators' pitch is locked to a single master oscillator, you're not going to be able to alter the pitch of one of the oscillators in any way without also changing the pitch of the other.
a|x
Dave
Sent: Saturday, November 15, 2008 2:45 PM
Subject: [korgpolyex] ARP, DCO and EG3
HI Dave,
Mike
mention velocity sensitivity. ..
in our Korgs.
> thanks!
> Dave
> From: Atom Smasher
> To: korgpolyex@yahoogro ups.com
wikipedia
level".
> ...atom
> -- E.B. White
Hi there Mike!
Dave
HI Dave,
Mike
in our Korgs.
> thanks!
> Dave
> From: Atom Smasher
wikipedia
level".
> ...atom
> -- E.B. White
Re: ARP, DCO and EG3
That is precisely the case.
One master clock = One bend.
Just so you know, I did contemplate building a second master
oscillator. But then, I would also have to build a new pair of digital
to analog converters or atleast build a new sample and hold that would
split the existing pitch bend into two, one for each OSC.
The end result is that I decided I against because of CPU cycles and
hardware and I'll end up dead of old age before this is all over with.
So I figure I am going to build my own synth pretty soon.
Mike.
> > Hi there Mike!
> a|x
> > Dave
> > From: korgpolyex800
> > HI Dave,
> > indeed.
> > Mike
> > --- In korgpolyex@yahoogroups.com, "David Mochen" <davidmochen@>
> > in our Korgs.
> > > thanks!
> > > Dave
> > > From: Atom Smasher
> > wikipedia
> > level".
> > > ...atom
> > > -- E.B. White
Re: [korgpolyex] Re: ARP, DCO and EG3
there's a detune parameter, right? would it be feasible to assign
modulation (ENV, LFO, etc) to the detune?
that would effectively allow the desired result... or would that also have
too much coding/CPU overheard? or would it produce a zipper, which would
sound like crap (zipper on some parameters could sound funky, but on a DCO
tune it would sound like crap)?
thanks...
...atom
"According to the Environmental Protection Agency, factory farming
pollutes U.S. waterways more than all industrial sources combined."
-- PETA
"The livestock sector is a major player [in climate change],
responsible for 18% of greenhouse gas emissions measured in
CO2 equivalent. This is a higher share than transport."
-- Livestock's long shadow, 2006
UN report sponsored by WTO, EU, AS-AID, FAO, et al
Detune only has 3 steps though.
a|x
> also have
> would
> a DCO
> thanks...
> ...atom
> -- PETA
in the original firmware, yes....
...atom
"If we don't stop extending our troops all around the
world in nation-building missions, then we're going
to have a serious problem coming down the road."
-- George W. Bush, to Al Gore, during Campaign 2000.
The detune is a nasty little shift register used to modulate the phase
of the master. The master clock always goes into DCO1 and the awfully
phase shifted clock goes into DCO2.
It's just awful but it does work.
But it doesn't remotely resemble pitch modulation.
also have
would
a DCO
> thanks...
> ...atom
> -- PETA
2008-11-16 by David Mochen
Thnks Mike and you guys. Got it. No fancy independent DCO pitch shifting.
cheers
dave
Sent: Saturday, November 15, 2008 5:16 PM
Subject: [korgpolyex] Re: ARP, DCO and EG3
also have
would
a DCO
> thanks...
> ...atom
> -- PETA
