moog slayer pots
2006-04-05 by jure zitnik
Index last updated: 2026-03-31 23:23 UTC
2006-04-05 by Atom Smasher
> hello, i'd just like to ask how much difference would it make if i used===============
> 47k pots instead of 50k ones? 50k pots are quite difficult to get here.
> maybe if i wire a resistor in serial?
2006-04-06 by jure zitnik
> 47K pots should be fine.
> ...atom
> ________________________
> http://atom.smasher.org/
> 762A 3B98 A3C3 96C9 C6B7 582A B88D 52E4 D9F5 7808
> "To announce that there must be no criticism of the
> president, or that we are to stand by the president,
> right or wrong, is not only unpatriotic and servile,
> but morally treasonable to the American public."
> -- Theodore Roosevelt
> YAHOO! GROUPS LINKS
> Visit your group "korgpolyex" on the web.
> korgpolyex-unsubscribe@yahoogroups.com
> Your use of Yahoo! Groups is subject to the Yahoo! Terms of Service.
2006-04-06 by austeritygirlone
> then i was trying to make DCO->VCF modulation but i found out that the
> DCO outputs are offset by +5VDC or so... i kinda figured that out
> without an oscilloscope - just with a multimeter and
> wires->mixer->soundcard and trial and error. is that true? what's the
> easiest way to drop that signal down 5VDC? i think it can make quite a
> nice mod.
On 4/6/06, austeritygirlone <ziggystar@...> wrote:
> I don't own an oscilloscope myself. But if the DCO outputs are offset
> by +5V, thus oscillating around +5V you can make a symmetrical signal,
> thus one that oscillates around +0V, simply by running it serially
> through a capacitor, removing the very low frequencies. Select it
> large enough to let all desired frequencies pass nicely. Then you
> could control the voltage range by a potentiometer. This would most
> probably be a nice mod. I'm not looking at the schematics, but since
> you now have two drivers for one input (VCF-Cutoff), you should
> connect them through a resistor or something, so that you don't create
> any short circuit.
> I'm new to this stuff, so please correct me if something is wrong. :)
> > nice mod.
> YAHOO! GROUPS LINKS
> hehe i'm even more new to this stuff and i really don't understand how
> running AC signal through a cap eliminates the DC offset... shouldn't
> that eliminate the high frequencies (and thus the oscillation)?
> jure
> A cap can be considered as a frequency dependant resistor. High freqs
> can pass and low freqs can't.
> Have a look at this picture:
> http://www.elecdesign.com/Files/29/1478/Figure_01.gif
> The +5V offset can be considered a very, very low frequency (f->0).
> On the other hand you can construct a lp filter, by "shortening" the
> high frequencies through a cap. Then you have to take the signal from
> before the cap, because the low frequencies stay there.
> > jure
> YAHOO! GROUPS LINKS
2006-04-06 by Atom Smasher
> hehe i'm even more new to this stuff and i really don't understand how======================
On 4/6/06, Atom Smasher <atom@...> wrote:On Thu, 6 Apr 2006, jure zitnik wrote:
> that eliminate the high frequencies (and thus the oscillation)?======================
gimme a few weeks... if i don't post details about how to add this to a
moog slayer then start harassing me.
...atom
"Computers in the future may weigh no more than 1.5 tons."
-- Popular Mechanics, 1949
SPONSORED LINKSMusic sampler Music synthesizers Synthesizer music Synthesizer Sampler
YAHOO! GROUPS LINKS
- Visit your group "korgpolyex" on the web.
- To unsubscribe from this group, send an email to:
- Your use of Yahoo! Groups is subject to the Yahoo! Terms of Service .
2006-04-08 by Atom Smasher
> yeah i did it yesterday and it's fine. the only thing i'll change is to=================
> replace the resonance pot with a linear one. the lower half of resonance
> range has practically zero effect and at ~3 o'clock it jumps straight
> into self-oscillation. anyone using a linear pot for resonance?
> i also did the filter 2/4pole switch and i LOVE the 12db/oct response! i===================
> like it TONS better than the original 24db/oct! i really recommend that
> to everyone.
2006-04-08 by jure zitnik
> try using different resonance settings in the DCF (parameter 42). you may
> want to change some settings after the mod to find the range of the knob
> that works best.
> > to everyone.
> does that sound more like an oberheim?
> ...atom
> "I recognize that a class of criminals and juvenile
> delinquents has taken to calling themselves
> 'hackers', but I consider them irrelevant to the
> true meaning of the word; just as the Mafia calls
> themselves 'businessmen' but nobody pays that fact
> any attention."
> -- Robert Bickford
> YAHOO! GROUPS LINKS
