EXS 24 Logic Sampler Users Group group photo
Index last updated: 2026-04-28 23:25 UTC
Switching Between multiple layered patches
2003-03-15 by kurtgoebel@aol.com
In a message dated 3/14/03 4:50:20 PM, exs-users@yahoogroups.com writes:
> Load the next program in the
> >EXS, and open another Instrument Editor window.  In the 1st editor,
> >select all, copy, and in the 2nd editor window paste.  Then 'save as'
> >new program name
To take this thread to the next level....If I imported another patch and made
a 2nd layer, such as a marcato string on top of a legato patch, how could I
smoothly switch between the two patches with say the mod wheel?   Thanks.
kurt
Re: [EXS] Switching Between multiple layered patches
2003-03-15 by Murray McDowall
Instead of doing this in the groups in the instrument editor (as you might
expect) you do it on the main EXS24  interface.
Map Controller 1 to "Sample Select" in the Matrix. The values you set for
velocity switching on the Zones or Groups will now be the crossover points. If
you have X layers then every note will now use X voices. Turn on crossfading if
you want a smooth transition.
 One limitation you might strike is that you can't have velocity switching and
crossfading simultaneously. If you have muliple velocity layers in your
separate articulations you are better to use the key switching that you set up
in the groups in the editors (select by).
Hope this helps,
Murray
