[exs] Re: Spectrasonics STYLUS
2002-08-31 by teddybut
> I bought it too, but I´m not really impressed so far: its socalled "vinyl > sound" is very clean, too much room and modulation, too many processed similar > loops (variations), it is very much mainstream. Some loops are dated!! The > big plus is the concept behind, the groovefiles. If the sounds would kick > more, if it would be more like a funky drummer, it would be my tool...I know, > just a matter of taste, but after reading only postings in this group praising > Spectrasonics, sometimes thiis forum seems to be a advertisement > platform...Sometimes I think we should discuss how to make samples by > ourselves instead of "whow there´s a fantastic new library out, let´s buy it" > Cheers Joh I'm sure Stylus is a very well put together product. I bought Distorted Reality when it came out cause a friend of mine was praising it. I was initially very impressed with Eric's programming and processing skills which are extremely impressive. I used that CD once and after that everything on there just seemed too pre-processed for my music. It ended up feeling like I was playing in a band with EP and his stamp was on my music. Then I heard those types of sounds on TV and whoosh, I forgot about all that library stuff and started making my own sounds exclusively. Using Distorted Reality did inspire me to figure out how to use my own processing to get similar effects, but with every Tom Dick and Harry using those samples on TV it's hard for me to use them in an original context. In my world, there's a place for libraries and a place for original sounds equally. If you make original sounding, cutting edge music only you're going to need lots of original sounds that you tailor to your own taste. If you make music that needs lots of real instruments, like orchestras and pianos and dulcimers, i.e. Film scoring/ Jingles... you'll need libraries. Keep in mind that one man's "cutting edge" is another man's "mundane" and vice versa. Teddybut PS Why don't you start the discussion on "how to make samples by ourselves"?
