Re: [exs] How do you generate an audio track with the EXS24 with Logic?
2002-01-06 by Ned Bouhalassa
Bonjour Francois,
When you select the 'bounce' function, a window
pops up. In that window, you have to specify the
number of length of your bounce in bars -
sometimes it says, "there's nothing to bounce", or
something like that, but ignore the message and
type in the beginning and end of your bounce in
the bars fields. Import your groove control loop,
click bounce and enter bars 1-9, for eg. Voila!
Too bad there's nothing about this in the EXS
manual...
Bonne chance!
Ned
Francois Delorme wrote:
> Hi!
> I am new to both Logic and the EXS24. I am trying to generate an audio
> track with Logic using a sample from Spectrasonics.
> I can import the sample without any problems. However, I don't seem to
> be able to generate an audio track. Using the Groove Control feature, I
> inserted the .iso track on the first audio track where my EXS24 is
> specified. Playback works fine. However, I want to generate a audio
> track from this. The Bounce operation does not work as I can't generate
> activity on the output 1-2 strip (although there is on track 1).
> Everything works fine if I insert an audio track.
> I suspect that because the Groove Control track is a Midi track, that's
> why I can"t generate sound on the master output 1-2 strip.
> Is there something specific that has to be specified on the EXS24 itself
> (in terms of output??)??
> I would appreciate some help from people that are able to do the same thing.
> Thanks in advance.
> Francois
> Yahoo! Groups Sponsor
> ADVERTISEMENT
> <http://rd.yahoo.com/M=216105.1806326.3318126.1261774/D=egroupweb/S=1705017563:HM/A=915128/R=0/O=1/I=brandr-lrec/postholidaygroup/*http://shopping.yahoo.com/domain?d=holiday&cf=posthol01>
> exs-users-unsubscribe@egroups.com
> Your use of Yahoo! Groups is subject to the Yahoo! Terms of Service
> <http://docs.yahoo.com/info/terms/>.
http://www.nedfx.com
Ned Bouhalassa
n e d @ n e d f x . c o m
