Re: LA-Mac] Re: Erro code?!
2001-08-19 by Martin Karlegard
Hi, You bounce your Audioinstruments exactly the same way you bounce audio. You should also make sure you bypass or remove every plugin that's not acually in use. I've noticed that on audioinstruments they take up cpu even when not used. Mardyk
> Från: exs-users@yahoogroups.com > Svara till: exs-users@yahoogroups.com > Datum: 19 Aug 2001 09:43:51 -0000 > Till: exs-users@yahoogroups.com > Ämne: [exs] Digest Number 309 > > LA-Mac] Re: Erro code?! > > Hi, > I get the same error message (-10011) on my G3 > 400 laptop with the VX pocket. When I look at the > activity on the CPU meter...it's loafing. The audio > processor seems to be working pretty hard but I > don't think I'm runing enough through the system > to cause that kind of load. > > I have 23 instances of the EXS open but only > seven active at the point in question...all > mono...and one additional stereo audio track. > One plugin on Bus 1-2...silververb. If i'm not > mistaken, I used to be able to play at least twice > the number of audio tracks. Any ideas? > > Also...and please bear with me. Realizing that the > tracks of the EXS contain midi info, is there any > way to bounce them like you can actual audio > tracks? I'm trying to streamline the audio output > for obvious reasons. > > Thanks > Julie
