Hi Guys,
The Mac program by Bitheadz called Osmosis does work for a decent basic level
of Roland to SampleCell/EXS conversion (including patches and performances).
The only thing with Groove Control library conversion is that S-Cell has a 59
key split limit. This is one of the reasons that we don't support Groove
Control products on SampleCell format. So if you convert Roland Groove
Control files to SampleCell via Osmosis, and then open it up in the EXS,
basically everything works except for loops that are four bars long and have
over 59 slices/partials.
So for GC it actually works about 85%-90% of the time...not bad really.
Definitely a good way to go for the time being. (It is actually much easier
in practice than it sounds).
BTW, if you really want native Roland support (or any other format), you
should tell emagic loudly. I could be wrong, but I don't believe that there
are any plans to support native import of any other formats currently. It's
probably speak now, or forever hold your peace! Send your requests directly
to Germany if this is something that you see as essential, and explain why
the other available solutions don't work for you.
Best regards,
Eric Persing
Creative Director
Spectrasonics
http://www.spectrasonics.net/
Learn more about Groove Control at:
http://www.spectrasonics.net/groovecontrol.html
>> Go to Bitheadz and download the free Osmosis (mac) demo! You can
>>convert 20 Roland multisamples (one per session) easily and use them
>>with the EXS-24.
>Converting samples is not a problem - I can import as many as I like
>with Transferstation (albeit one at a time). Does the Osmosis demo
>translate complete patches? If you're using Groove Control patches,
>you'll know there can be HUNDREDS of samples in a patch. I want the
>facility to simply load a Roland patch, with velocity layering,
>keyboard mapping and all.
>> I'm sure that Emagic will improve the scope of their softsampler to
>>exceed my Kurzweils (including Roland reading , streaming,
>>and matrix modulation capabilities. Just give em a little time...
>I hope you're right........
