Re: [EXS] Mod Wheel
2005-04-01 by Sascha Franck
> Is there an easy way to assign a controller like Mod > wheel to a filter in EXS? Or how to do it properly? Do > I need to assign a controller number & whats the > controller number for Pitch Bend & Mod Wheel? In the modulation router (bottom of the EXS), assign "Dest" to Filter Cutoff, then select "Ctrl #1" (which would be your ModWheel) in the "Src" pulldown and drag the slider right from them up/down, depending on whether you want positive or negative cutoff modulations (middle position is allways equivalent to the actual cutoff button setting). - Sascha
