EXS 24 Logic Sampler Users Group group photo
Index last updated: 2026-04-28 23:25 UTC
Roland samples into EXS format...problems with Translator....what' best?
2003-12-12 by bach122001
Hi all,
I'm trying to get my Roland CDrom's into my EXSmkii. I'm using Chicken Translator's
latest 'EXS Special Edition 1.5.8'. I've tried both OSX and OS9.....some translations got
hung up in OSX and stopped at a certain point.
- after translating, some samples 'can't be found' upon attempting playback
- anyone know how to get 'Denny Jaeger Strings' to react to CC controller 64? how to
set it up in the EXS?
- is CDExtract any more consistent?
Thanks all.
Cam Millar
artfarm1@...
Re: Roland samples into EXS format...problems with Translator....what' best?
2003-12-13 by Mark
I  haven't used Chicken Sys extensively but I do use CDXtract quite
frequently to convert my AKAI CDs to EXS24 and it works perfect and
is a joy to use.  On Windows the interface seems a bit more straight
forward and flexible thatn Chicken Sys.  I've never tried a Roland CD
though.
The reason I use CDXtract instead of letting EXS do the Akai
conversion is folder organization is a bit more flexible especially
during the conversion process you are prompted with many options
before the conversion begins so when it's done you can get started
playing right away. If I use EXS to convert my Akai CDs I have to do
some post follow up work to clean it up and organize.  With CDXtract
all the option are selectable before pressing the "Convert" button.
Mark
--- In exs-users@yahoogroups.com, "bach122001" <artfarm1@e...> wrote:
> Hi all,
playback
> Thanks all.
> Cam Millar
> artfarm1@e...
Re: [EXS] Roland samples into EXS format...
2003-12-13 by Garth Hjelte
>Translator's
>translations got
Please use our Bug Reports page listed in your manual or email us with the
pertinent info. We've done a number of Roland CD's (about 25 or 30) for our
test-beds with great results.
Also note that 1.5 Build 9 is up and may solve a quirk or two.
Garth Hjelte
Sampler User
2003-12-13 by Cam Millar
> the
> for our
> Garth Hjelte
> Sampler User
Garth, thanks for monitoring that web site and writing back. I thought
I'd throw the question out there to some people.
I did have a couple of buggy things happen with 1.5.8. When translating
my 'Denny Jaeger strings' in OSX, Translator got hung up and stopped
about 75% of the way through when it got the same spot it hung up in
older Translator 1.5.6 and .7
It worked in OS9, but then when trying to play back I got some 'can't
find samples' warnings from the EXS.
I got the same notice when i translated the Roland Rhythm Section cd
rom, that it couldn't find the piano samples for the YC7 piano group.
I'll download the new version 1.5.9 this weekend. Thank you!
I'll keep you informed.
Cam Millar
artfarm1@...
Which ones are they? I successfully did Denny Performances, and Patches,
did some quick tests and things sounded OK. Separate folders were made and
aliases created successfully. In OSX. Must be 1.5 9?
We'll try that in our rotation this weekend. Thanks!
Garth Hjelte
Sampler User
I tried Panther and Jaguar as well.
Garth Hjelte
Sampler User
