EXS 24 Logic Sampler Users Group group photo
Index last updated: 2026-04-28 23:25 UTC
Wrong name,correct patch and other probs
2003-10-20 by orgeneral
Hi
I am still having serious problems with exs24.maybe you remember my
previous post.
First problem is
when I select patches sometimes wrong names come up but with correct
sounds.and that wrong name says there although i change the patch.
I will try to explain how this happens.I installed xtreme digital
today.I select a patch and i get a patch name from xx large pad
(chord pad82)i select another patch from xtreme digi lib,the sound
changes but the name is still chord pad 82.Also I had to take out
some exs patches from sample instruments folder otherwise i can not
load anything.this happened before.ý know there is alimit for sample
instruments but all my sounds are neatly in folders and sub
folders.so thats not it.TO be able to load xtreme digital i had to
take out another library.if instead i take out xtreme digital it
works fine again.i trashed the prefs but no help.
i hope i made my self clear.
g4 mdd dual1
osx.2.6
logic 6.2 6.3
2 external firewire for samples
1 internal for audio recording.
motu828
protools hd3
thanks in advance
oz
