eml synthesizers group photo
eml synthesizers
Archive for emlsynth.
Index last updated: 2026-03-30 01:08 UTC
Sequencing an EML-101
2008-05-09 by mfretton
OK I've scoured these posts (& those on Analogue Heaven & elsewhere) and it seems that
the best way (the only way?) to control an EML-101 properly from a CV/gate sequencer is
via the keyboard socket, as the external control jacks only control two of the VCOs.
Unfortunately I've not found a conclusive/definitive way of doing this, partly because there
appear to be variations on the keyboard socket & wiring (mine is an odd 5-pin reminiscent
of a DIN plug). I don't wish to be able to play the 101 when it's being sequenced, so ideally
would plug the sequencer into the keyboard socket - what are these plugs/sockets called?
I know that the EML-101 is 1.v/octave although I'd think that a CV sequencer like the
Korg SQ-10 would work fine, since each note is set manually.
So...how do I do it?
Matt
PS of course in a perfect world I'd buy the 400/401 if:
a. I could find them
b. I could afford them
Re: [emlsynth] Sequencing an EML-101
2008-05-09 by sascha victoria
An EML 400 won't solve your problems unless you want to modify your 101. The best bet for sequencing a 101 is a Kenton MIDI / CV converter...
Matt
2008-05-09 by Matt Fretton
...but where would I plug the Kenton into the 101? If you use the
jacks at the top left, you can only control two oscilators, hence my
interest in using the Keyboard socket.
Oh & I didn't mean that the 400 would sequence the 101, just that if I
had the 400/401 I wouldn't need to sequence the 101!
2008/5/9 sascha victoria <sascha.victoria@...>:
>> it seems that
>> sequencer is
>> the VCOs.
>> 5-pin reminiscent
>> sequencer like the
>> Matt
Ah... I see your problem. Not sure how you'd access KB1 and KB2. You're probably right on your keyboard jack mod theory...
