eml synthesizers group photo
eml synthesizers
Archive for emlsynth.
Index last updated: 2026-03-30 01:08 UTC
External CV of EML101
2006-12-23 by kyhotay
I am trying to interface my EML101 to an Encore Expressionist MIDI>CV
converter and am having a heck of a time trying to get the synth to
track somewhat chromatically. The patch panel doesn't have the
sequencer input but does have the OCS1 Ext CV in. It seems that there
are several interactive pots to set pitch but I have no idea how to
make it work.
Any suggestions?
Brian Folkes
Re: External CV of EML101
2006-12-29 by nicholas_kent
> make it work.
> Any suggestions?
> Brian Folkes
You can't get the whole instrument to follow any jack and knob combos and the external
CV seems to have been intended for modulation, and only one envelope will respond to
the Trig in.
What I figured out was I could tap into the keyboard jack by unscrewing the plug. That way
I could see which pin is what. I posted my findings on Analogue Heaven years ago though
I've heard from someone with a different keyboard connector. Anyway one of the pins is
like an offset for the duophony. You'd probably not want to mess with it until you master
getting CV/Gate to work. The other thing that really threw me for about an hour is that
when the EML receives a gate there is an internal buffer that samples and holds the CV
coming in when the gate goes on. So if you are tweaking the CV on the expressionist you
won't hear a change until you send a new gate. This might be the reason for the CV input
jack that seems meant only for modulation. You can't modulate your incoming CV (though
obviously there are many modulation opportunities within the EML.
Also, while it may be obvious for "old pros". I found the best way to get it to track is to
temporarily forget about pitch, just get one octave to respond to one octave even if the "C"
sounds as an "F" a quater tone sharp or something. Once you get your octaves to be
octaves then it's a piece of cake to just make the C to a C with tuning
2007-01-18 by rob80b
Brian,
Back in the early 80's I got a voltage convertor from Dale Blake for
my 101, I also recieved the schematics and installation instructions
and so built another for my 500.
If I can track someone down with a scanner I'll post them here.
Basically the voltage convertor takes the 1 volt per octave input from
any sequencer (I was using an Arp but later Rolands MPU101 midi to cv
convertor)and scales it to be used with EML's 1.2 volt per octave
system. It works great and cost a few dollars in parts.
there
> > make it work.
> > Any suggestions?
> > Brian Folkes
will respond to
> the Trig in.
one of the pins is
incoming CV (though
octaves to be
2007-01-19 by Brian Folkes
Rob,
I appreciate that. Theoretically the Expressionist should be able to do that with the tracking and offset controls, but I can't hear a difference even at the extreme of settings.
Brian
2007-01-23 by rob80b
Hi Brian
It's been awhile, 25 years but there was a difference depending if the
control voltage was handled exponentially or linear.
If you are able to offset the input voltage you need to go through the
sequencer in jack labeled CM2/CM3 or Seq1/Seq2.
The oscillator control panel will not work OSC4/ext will not track
properly.
If I remember correctly I have the voltage converter placed just after
the Sequencer in jack. In Jack>Voltage converter>101 board, although
going external would be the same thing.
Make sure you are tuning properly (you may already know this), start
with octaves, then intervals, so when off-setting the voltage first
tune for middle C and the offset the voltage to track a few workable
octaves up.
The higher notes are the most noticeable so start from the tracking
from the bottom octave and fine-tune the octaves at the top and then
the bottom octave. You will probably be required to do this a few times.
Now it may be that your Encore Expressionist does not have enough
voltage gain, 1.2 volts per octave to accommodate the EMLs.
Good Luck
Robert
--- In emlsynth@yahoogroups.com, "Brian Folkes" <brianfolkes@...> wrote:
> Rob,
> Brian
2007-05-16 by Dan Levey
I'm a bit late on getting in on this but I have managed to play my
101 by Midi with a bit crazy workaround but all external and needing
a computer sequencer.
I found that the "External Osc Control" input is the only one that
can control all 4 Osc's equally. You have to turn the Control Knob
all the way to the left as well. The problem is, This input is not
scaled for anywhere near 1 - 1.2v/Oct, it needs about 3 or more
volts/oct to track correctly. As a quick solution, I went into
Cubase and set up a transform midi track to multiply any note I play
by 3.2. That makes the 101 track perfect with about a 2 octave range
before midi notes run out. I can play the 101 keyboard to set the
octave ranges my midi will control.
Also, if you patch Gate into the External Env control, you will find
that there is no ENV 1 External control input. What I did is buy a
Doepfer envelope and power connector and have that patched into the
Filter CV so it triggers along with everything else.
Lots of work but it all works for me.
Dan
http://www.REwireMusic.com
2007-05-29 by nicholas_kent
If you have a mixer that works with CV (I picked up a doepfer one on ebay for $12, but
that was a fluke), yoy can do all sorts of useful things. For instance you could easily mix in
a constant 2 or 3 volts. Some EMLs even have a utility voltage out. Also you can send your
CV converter to 2 mixer inputs if it won't do 1.2v on it's own.
As for the External Osc Control, the one on mine is fine for an external LFO or something
but mine at least tracked exponential not linear as far as I could tell. Though I don't know
if I messed with the range enough. I do remember I needed at least 3v to get it doing
much.
Did you get both envelopes to fire? The trigger input on my unit I think intentionally only
fired one EG. This of course can be a good feature once you gain contol of the other by
some other means. That's one of the reasons I gave up with a patchcord interfacae and
looked at the keyboard connector when I interfaced mine to CV
> Dan
