Emax
SP12 OLED install help
2013-08-22 by plus_321
Hi, I know it's not an emax, but I'm just looking for a little bit of help putting in an oled in an sp12.
I put it in and this is what I get:
https://www.dropbox.com/s/uu5tudvmpri3097/sp12backwards_.jpg
This is the sheet for the display I installed:
http://www.newhavendisplay.com/specs/NHD-0216KZW-AY5.pdf
This is the sheet for the original display:
http://pdf1.alldatasheet.com/datasheet-pdf/view/92672/OPTREX/DMC16207.html
I just can't figure out why it's printing backwards and offset.
I tried reversing the data lines and it didn't even start.  The sp12 works fine, just backwards and scrambled on some things.
I looked at the pinouts on these two displays and they seem to match fine.  My connections are all continuous and I triple checked the solder joints on every one.
The new display has jumpers for 6800 or 8080 mode and is in 6800 as stock.  Could this be an issue?  I checked with my meter that pin 1 is gnd and pin 2 is +5v so that's good.
I'm out of things to check now and hoping someone has seen something like this.
