Emax
Emax HD vs Emax II - which to repair
2012-07-25 by djo3yk
I have an Emax HD with a faulty PSU and 7 broken keys.  I also have an Emax II with a faulty disk drive.
Was wondering if it would possible to swap the PSU from the Emax II into Emax I as well as the entire keybed?
I would prefer using the analog filter of the Emax I; however, if this is not possible then is it possible to swap out the HD and the Floppy drive from the Emax I and pop it into the Emax II?
Thanks.
Re: [emax] Emax HD vs Emax II - which to repair
2012-07-25 by Ted Summers
Why not fix them both?
PSU can be had from EPR electronics (they were in stock yesterday when I looked at their website).
keys are available- either ebay or I have some
Faulty disk drive can be replaced also, or swap out floppy disk for slim floppy and a Flash media drive like PCD-50b and get rid of possible HD failure and move into year 2000 :-)
HD in Emax 1 is only 20MB and HD in Emax2 is 512MB- so big difference there.
Sad to breakdown a piece of equipment relatively easily fixed...
Thanks.
2012-07-25 by jammie
yes
  To: emax@yahoogroups.com
  Sent: Wednesday, July 25, 2012 2:30 AM
  Subject: [emax] Emax HD vs Emax II - which to repair
  Thanks.
Re: Emax HD vs Emax II - which to repair
2012-07-28 by jaumemod
Cheapest: repair Emax II PSU, repair Floppy faulty put your Emax II MASTER on Emax I slave MIDI
> Thanks.
Re: [emax] Re: Emax HD vs Emax II - which to repair
2012-07-28 by j k
Took out the PSU from the Emax II and popped it into the Emax I.  PSU success.
Powered up the Emax I but with diagnostics on LCD and the Preset Definition light and Analog processing LEd on -- hence I think the Mitshubishi MF353B FDD from the Emax I is toast.  Popped in the EMax II Mitshubishi MF353BA FDD into the Emax I -- It just displayed system loading on the LCD (even with the HD removed).  Not sure if its the drive or my floppy disks.
Sent: Saturday, July 28, 2012 4:15:54 PM
Subject: [emax] Re: Emax HD vs Emax II - which to repair
> Thanks.
