Trouble with discs written using Emx
2002-10-23 by lasselakstrup
I have tried to write discs on my IBM using Emx. When I load them into my emax the sounds are a bit screwed up. It sounds like some sort of extreme tremolo - not very nice... Do I need some drivers or something?
2002-10-24 by Matt Ferrari
the only thing i can suggest is that you make sure you use the program in dos and i mean dos! it will run under windows but the disks dont work then Matt ----- Original Message -----
From: "lasselakstrup" <lasse@...> To: <emax@yahoogroups.com> Sent: Wednesday, October 23, 2002 5:25 PM Subject: [emax] Trouble with discs written using Emx > I have tried to write discs on my IBM using Emx. When I load them > into my emax the sounds are a bit screwed up. It sounds like some > sort of extreme tremolo - not very nice... > Do I need some drivers or something? > > > > Emax and Emax II User's Group Website > > http://www.silveriafamily.com > > Your use of Yahoo! Groups is subject to http://docs.yahoo.com/info/terms/ > >
2002-10-24 by lasselakstrup
I just tried it in ms dos and the result was still bad (maybe even worse). Any other suggestions? Lasse --- In emax@y..., "Matt Ferrari" <ferrari5@a...> wrote: > the only thing i can suggest is that you make sure you use > the program in dos and i mean dos! > it will run under windows but the disks dont work then > > Matt > ----- Original Message ----- > From: "lasselakstrup" <lasse@t...> > To: <emax@y...> > Sent: Wednesday, October 23, 2002 5:25 PM > Subject: [emax] Trouble with discs written using Emx > > > > I have tried to write discs on my IBM using Emx. When I load them > > into my emax the sounds are a bit screwed up. It sounds like some > > sort of extreme tremolo - not very nice... > > Do I need some drivers or something? > > > > > > > > Emax and Emax II User's Group Website > > > > http://www.silveriafamily.com > > > > Your use of Yahoo! Groups is subject to http://docs.yahoo.com/info/terms/ > > > >
2002-10-24 by Richard Spoula
Its been my experience that the disks above the number ZD749 come out corrupt. I believe that Emx is having trouble coping with the modern computers. I myself have not had any luck even booting my computer from floppy and DOS 6.22 on disks above the ZD749. I do get the disks below ZD749 to work in Windows 98 Dos mode (not Dos window) you know "exit to Dos mode." Try some of the lower number and see if you can get those to work. Skip
----- Original Message ----- From: lasselakstrup Sent: Thursday, October 24, 2002 7:18 AM To: emax@yahoogroups.com Subject: [emax] Re: Trouble with discs written using Emx I just tried it in ms dos and the result was still bad (maybe even worse). Any other suggestions? Lasse --- In emax@y..., "Matt Ferrari" <ferrari5@a...> wrote: > the only thing i can suggest is that you make sure you use > the program in dos and i mean dos! > it will run under windows but the disks dont work then > > Matt > ----- Original Message ----- > From: "lasselakstrup" <lasse@t...> > To: <emax@y...> > Sent: Wednesday, October 23, 2002 5:25 PM > Subject: [emax] Trouble with discs written using Emx > > > > I have tried to write discs on my IBM using Emx. When I load them > > into my emax the sounds are a bit screwed up. It sounds like some > > sort of extreme tremolo - not very nice... > > Do I need some drivers or something? > > > > > > > > Emax and Emax II User's Group Website > > > > http://www.silveriafamily.com > > > > Your use of Yahoo! Groups is subject to http://docs.yahoo.com/info/terms/ > > > > Yahoo! Groups Sponsor ADVERTISEMENT Emax and Emax II User's Group Website http://www.silveriafamily.com Your use of Yahoo! Groups is subject to the Yahoo! Terms of Service. [Non-text portions of this message have been removed]
2002-10-24 by Ben & Mana Model
I've had best results with this using an older DOS, like the one used on Windows 95 or earlier than that. I've hung on to an old Windows 3.1 laptop for this use.
> From: "Richard Spoula" <skiplay4@...> > Reply-To: emax@yahoogroups.com > Date: Thu, 24 Oct 2002 07:36:44 -0500 > To: <emax@yahoogroups.com> > Subject: Re: [emax] Re: Trouble with discs written using Emx > > Its been my experience that the disks above the number ZD749 come out corrupt. > I believe that Emx is having trouble coping with the modern computers. I > myself have not had any luck even booting my computer from floppy and DOS 6.22 > on disks above the ZD749. I do get the disks below ZD749 to work in Windows 98 > Dos mode (not Dos window) you know "exit to Dos mode." Try some of the lower > number and see if you can get those to work. > Skip > > ----- Original Message ----- > From: lasselakstrup > Sent: Thursday, October 24, 2002 7:18 AM > To: emax@yahoogroups.com > Subject: [emax] Re: Trouble with discs written using Emx > > I just tried it in ms dos and the result was still bad (maybe even > worse). Any other suggestions? > > Lasse > > > --- In emax@y..., "Matt Ferrari" <ferrari5@a...> wrote: >> the only thing i can suggest is that you make sure you use >> the program in dos and i mean dos! >> it will run under windows but the disks dont work then >> >> Matt >> ----- Original Message ----- >> From: "lasselakstrup" <lasse@t...> >> To: <emax@y...> >> Sent: Wednesday, October 23, 2002 5:25 PM >> Subject: [emax] Trouble with discs written using Emx >> >> >>> I have tried to write discs on my IBM using Emx. When I load them >>> into my emax the sounds are a bit screwed up. It sounds like some >>> sort of extreme tremolo - not very nice... >>> Do I need some drivers or something? >>> >>> >>> >>> Emax and Emax II User's Group Website >>> >>> http://www.silveriafamily.com >>> >>> Your use of Yahoo! Groups is subject to > http://docs.yahoo.com/info/terms/ >>> >>> > > > Yahoo! Groups Sponsor > ADVERTISEMENT > > > > > > Emax and Emax II User's Group Website > > http://www.silveriafamily.com > > Your use of Yahoo! Groups is subject to the Yahoo! Terms of Service. > > > [Non-text portions of this message have been removed] > > > > Emax and Emax II User's Group Website > > http://www.silveriafamily.com > > Your use of Yahoo! Groups is subject to http://docs.yahoo.com/info/terms/ > >
2002-10-24 by Bob Conner
What is ZD749? Is this the name/volume the computer gives the floppy? If so you could manually rename the disk volume. Bob --- Richard Spoula <skiplay4@...> wrote: > Its been my experience that the disks above the > number ZD749 come out corrupt. I believe that Emx is > having trouble coping with the modern computers. I > myself have not had any luck even booting my > computer from floppy and DOS 6.22 on disks above the > ZD749. I do get the disks below ZD749 to work in > Windows 98 Dos mode (not Dos window) you know "exit > to Dos mode." Try some of the lower number and see > if you can get those to work. > Skip > > ----- Original Message ----- > From: lasselakstrup > Sent: Thursday, October 24, 2002 7:18 AM > To: emax@yahoogroups.com > Subject: [emax] Re: Trouble with discs written using > Emx > > I just tried it in ms dos and the result was still > bad (maybe even > worse). Any other suggestions? > > Lasse > > > --- In emax@y..., "Matt Ferrari" <ferrari5@a...> > wrote: > > the only thing i can suggest is that you make sure > you use > > the program in dos and i mean dos! > > it will run under windows but the disks dont work > then > > > > Matt > > ----- Original Message ----- > > From: "lasselakstrup" <lasse@t...> > > To: <emax@y...> > > Sent: Wednesday, October 23, 2002 5:25 PM > > Subject: [emax] Trouble with discs written using > Emx > > > > > > > I have tried to write discs on my IBM using Emx. > When I load them > > > into my emax the sounds are a bit screwed up. It > sounds like some > > > sort of extreme tremolo - not very nice... > > > Do I need some drivers or something? > > > > > > > > > > > > Emax and Emax II User's Group Website > > > > > > http://www.silveriafamily.com > > > > > > Your use of Yahoo! Groups is subject to > http://docs.yahoo.com/info/terms/ > > > > > > > > > Yahoo! Groups Sponsor > ADVERTISEMENT > > > > > > Emax and Emax II User's Group Website > > http://www.silveriafamily.com > > Your use of Yahoo! Groups is subject to the Yahoo! > Terms of Service. > > > [Non-text portions of this message have been > removed] > > __________________________________________________ Do you Yahoo!? Y! Web Hosting - Let the expert host your web site http://webhosting.yahoo.com/
2002-10-24 by John Silveria
ZD749 is the catalog number of the bank. Most of the Emax library is labelled ZDxxx.
On 24 Oct 2002 at 12:58, Bob Conner spoke unto me:
> What is ZD749?
> Bob
> > Skip
> > From: lasselakstrup
> > Emx
> > bad (maybe even
> > Lasse
> > you use
> > then
> > > Matt
> > > To: <emax@y...>
> > Emx
> > When I load them
> > sounds like some
> > ADVERTISEMENT
> > Terms of Service.
> > removed]
> Do you Yahoo!?
> ---------------------~--> Sell a Home with Ease!
> http://us.click.yahoo.com/SrPZMC/kTmEAA/jd3IAA/QnLolB/TM
**************************John Silveria II****************************
AIM & Yahoo! Messenger: EmaxJS
MSN: emaxjs@...
The Silveria Family Website & Emax and Emax II User's Group
------------------ http://www.silveriafamily.com ----------------------
