Here are some pics of the JM215A that a friend and I modified:
http://m.flickr.com/#/photos/<http://m.flickr.com/#/photos/krunkwerke/6024390494/>
krunkwerke/6024390494/ <http://m.flickr.com/#/photos/krunkwerke/6024390494/>
at the moment, the drive powers but, the Emax is still displaying "Please
Insert Disk!". Any ideas? Everything tested accurately with the continuity
tester.
Any advice is greatly appreciated.
-s*
On Mon, Aug 8, 2011 at 11:35 AM, Ted Summers <djtbs1@...> wrote:
> Send me pics of the mods made so far and I can see if anything is wrong
> there....
> On Mon, Aug 8, 2011 at 7:26 AM, Scott Stanley <scartattack@...>
> wrote:
> > My friend and I recently modded a JM215A for a Teac slim floppy drive
> using
> > Ted's instructions:
> > *JM215A Modifications:
> > Bottom of Board
> > FDC Pin2 connects to ITX pin 11. Cut this trace near pin 11.
> > Connect FDC Pin2 to ITX pin 13 with insulated 30ga jumper / wire wrapping
> > wire.
> > ITX pin 4 jumper to FDC10
> > Top of Board
> > With board "right side up" so that "C1" screened on the board is readable
> > and away from you, there are 5 traces that run a diagonal.
> > Cut the 2nd one away from you.
> > However, I am able to get the drive to power but, the Emax still does not
> > see the drive. I still get the message "please insert floppy".
> > Might anyone know anything else that I am missing?
> > Regards,
> > -Scott
> > <http://www.obsoletecomponents.ca>
> > [Non-text portions of this message have been removed]
> Emax and Emax II User's Group Website
> http://www.silveriafamily.comYahoo! Groups Links
