Emax
Emax Plus
Emax Plus
2010-03-16 by leavesstillgreen
So can anyone mail me/sell me an emax plus upgrade disk?  A floppy would work...or even better a zip 100 disk if that's possible.
Thanks!
RJ
Re: [emax] Emax Plus
2010-03-17 by RJ
nevermind, I was able to create my own.
Anybody know why I have to keep my original floppy drive in my emax along
with the scsi zip drive?
It loads up the OS from the zip drive only if the floppy drive is also
connected....otherwise it gets stuck at the diagnostics...
On Tue, Mar 16, 2010 at 1:10 PM, leavesstillgreen
> Thanks!
> RJ
2010-03-17 by Ted Summers
that is by design. it expects the floppy to be there.
along
> would
> Thanks!
> RJ
Emax and Emax II User's Group Website
http://www.silveriafamily.comYahoo! Groups Links
2010-03-17 by Dave Sotnick
Ah, yes but you can fool the Emax into thinking a floppy drive is present.
From my past post:
"You can jumper pins 25/26 on the floppy drive connector on the motherboard
(it's the /TRK0 sense pin which tells the Emax the drive head is on Track
0). Once you do this, you'll be able to boot the Emax with no floppy drive
attached."
-Dave
2010-03-17 by Rish
Hey all....I was out of stock on the 2010 Emax 1 /SE/HD and EMAX 2 floppy drives for sometime but I now have them available agian.
Stacy at  www.route66studios.com
  To: emax@yahoogroups.com
  Sent: Wednesday, March 17, 2010 11:43 AM
  Subject: Re: [emax] Emax Plus
  From my past post:
  attached."
  -Dave
2010-03-17 by RJ
Time to open it up for a third time... aaargh!
I've read the zip drive can be too much for the Emax PSU to handle.  Is this
true even if I don't have the floppy drive and hard drive connected?
> From my past post:
> attached."
> -Dave
> On Wed, Mar 17, 2010 at 6:48 AM, Ted Summers <djtbs1@...<djtbs1%40gmail.com>>
The zip drive uses less power than a hard drive. I ran my Emax with a Zip
and no floppy for a year or so with no ill effects. Still using the original
power supply.
-Dave
> this
