go to my livespace and see pics at the bottom of the page....
http://djtbs1.spaces.live.com/
Ted
On Oct 6, 2009, at 2:09 PM, roberth909 wrote:
I think a card reader is making a lot of sense. I'm only trying to use
the Zip drive because I already own it and it's not being used for
anything else. Heck, I have a 2GB SCSI Jaz that's not being used for
anything (where I can set the SCSI ID to anything), but that would
really be wasting storage space. Is there room to mount both a card
reader and a small floppy drive in the front of a keyboard Emax I?
Robert
--- In emax@yahoogroups.com, Chase Smith <plus_321@...> wrote:
> I haven't done what you are talking about because I have installed
an internal zip in my Emax, but there is a way you could do what you
are talking about.
> Get an external SCSI drive closure (from ebay or wherever) and put
an internal zip drive in the enclosure, then you will have an external
zip and you can set the ID to whatever you like. I actually have one
set up like this that I use sometimes for my Emax II. One day I might
install the external SCSI port and use it like that, but I think I
would prefer a card reader for less noise.
> Chase
> --- On Tue, 10/6/09, roberth909 <friction@...> wrote:
> From: roberth909 <friction@...>
> Subject: [emax] Re: DIsk Not Formatted!
> To: emax@yahoogroups.com
> Date: Tuesday, October 6, 2009, 1:49 AM
> I pried open the zip to see if there was some obvious way to
override and 5/6 switch and set it to 0, it didn't look very
promising. Has anyone else done this?
> --- In emax@yahoogroups. com, Ted Summers <djtbs1@> wrote:
> > Emax 2 you can set.
> > Emax 1 must be ID 0.
> > On Oct 5, 2009, at 9:22 PM, Elk Latham wrote:
> > Ted,
> > Are you sure about the ID 0 setting? if it's a SCSI zip
> > drive, you should be able to
> > tell the Emax in the master section what SCSI ID to boot from.
> > I don't use Zip drives, so I'm not sure..
> > ____________ _________ _________ __
> > From: Ted Summers <djtbs1@>
> > To: emax@yahoogroups. com
> > Sent: Monday, October 5, 2009 7:44:31 PM
> > Subject: Re: [emax] DIsk Not Formatted!
> > If when you formatted the zip you copied the plus OS to it, then
yes-
> > but keep in mind unless you have a Zip that can be set to ID0, the
> > Emax won't boot from it.
> > Regards,
> > Ted
> > On Oct 5, 2009, at 7:28 PM, roberth909 wrote:
> > Hello,
> > I bought a used Emax recently. Every now and then I get a "Disk Not
> > Formatted!" error when it's trying to load the software, and when
it
> > decides to move beyond the error, then the floppy seems to work
fine.
> > Now it seems to be in a state where I can't move beyond the error
and
> > I can't load the OS. I did successfully install an external SCSI
jack
> > and I was able to format a Zip disk a few days ago. Is there OS
Plus
> > 1.0 on the Zip disk? And if so can I get it to boot from the Zip
disk?
> > I've tried to insert the floppy again and again, I've repeatedly
> > rebooted the Emax, all I get is a crunching sound in the floppy
drive
> > and the error message like it's trying its best to read the
floppy but
> > just can't pull it off. Is it time replace the floppy drive, I'm
sure
> > it's the original drive.
> > Thanks!
> > Robert
> > [Non-text portions of this message have been removed]
