Emu Emax 1000 Keyboard having troubles setting up my HxC drive
2015-07-28 by shawnjward@...
I have an Emu Emax 1000 Keyboard Version 2 Rev C and im looking for an Emaxos.emx OS file that would be compatible with my version so i can load the OS on my HXc drive
after installing the HxC drive and setting up my SD properly with converted HFE files, it will read the banks but will not load them because i think i have the wrong OS in the CFG boot file in the root folder
any help would be greatly appreciated
2015-07-28 by Ted Summers
2015-07-28 by Shawn Ward
hi Ted.thanks for helping outunfortunately I don't have the original floppyI have confirmed the IC13 Eprom is non SCSI (IP349)the Tim Pal IC 49 has the SCSI feature lock on it also (PM7524) also there is no IC in IC6 socket so these would rule out any SCSI features/capabilitiesIm also almost positive its not an SEwhen i boot with the Emaxos.emx i found here it gives me a "wrong software" message http://hxc2001.free.fr/floppy_drive_emu ... emaxos.emxTo: emax@yahoogroups.com
Date: Tue, 28 Jul 2015 09:20:18 -0700
Subject: Re: [emax] Emu Emax 1000 Keyboard having troubles setting up my HxC drive
Shawn-What OS is on the floppy you were booting with prior to installing the HXc? You should use that OS as the starting point.If it wasn't ever booted (but you had added the HXc in hopes to boot it), then it's a bit more complicated, because we don't know if your Emax has SE, SCSI, etc.If you don't have SCSI (or don't know), and don't know if it has SE, then you should start with the Emax 3.2 OS as it will work on all models.The next step would be to determine what (if any) other features you have installed in the unit.The OS version (if you boot from your existing floppy) may give a clue - unless it's 3.2 as that had no support for the add-ins.Worst case- you create an floppy / HXc image location of the SE update, and boot from it- if it updates, you didn't have SE, and you now have SE- if it just boots, the unit was already SE.As to SCSI- you would have to open it up and consult my webpage for further:Please note that the installed features will determine what OS'es you can successfully boot from.-TOn Mon, Jul 27, 2015 at 9:54 PM, shawnjward@... [emax] <emax@yahoogroups.com> wrote:
thanks TedI'm having troubles finding out how to update this to SE with no floppy and just my HxC driveTo: emax@yahoogroups.com
Date: Tue, 28 Jul 2015 10:18:05 -0700
So you are trying to boot with an OS that is either SCSI, SE, or both which your unit doesn't have.I would suggest you first start with getting the SE image from the files section and then use that as your OS boot image, after the Emax is updated.-TOn Tue, Jul 28, 2015 at 10:11 AM, Shawn Ward shawnjward@hotmail.com [emax] <emax@yahoogroups.com> wrote:
Shawn-What OS is on the floppy you were booting with prior to installing the HXc? You should use that OS as the starting point.If it wasn't ever booted (but you had added the HXc in hopes to boot it), then it's a bit more complicated, because we don't know if your Emax has SE, SCSI, etc.If you don't have SCSI (or don't know), and don9;t know if it has SE, then you should start with the Emax 3.2 OS as it will work on all models.The next step would be to determine what (if any) other features you have installed in the unit.The OS version (if you boot from your existing floppy) may give a clue - unless it';s 3.2 as that had no support for the add-ins.Worst case- you create an floppy / HXc image location of the SE update, and boot from it- if it updates, you didn't have SE, and you now have SE- if it just boots, the unit was already SE.As to SCSI- you would have to open it up and consult my webpage for further:Please note that the installed features will determine what OS'es you can successfully boot from.-TOn Mon, Jul 27, 2015 at 9:54 PM, shawnjward@... [emax] <emax@yahoogroups.com> wrote:
