Emax
Emax 2 Case Repair
Emax 2 Case Repair
2015-07-17 by graham.hunter@...
I just received a second Emax 2 keyboard as a spare, but it was improperly packed and there's some damage to the case around the floppy drive.
Does anyone know what material the outer case is made of and/or what epoxy would be best to make the repair?
Thanks!
Re: [emax] Emax 2 Case Repair
2015-07-17 by Gary Doty
I use a black 2 part called Devcon Plastic welder for repairing Kurzweil K2000 cases. It works well for filling for broken out pieces and is easily workable with a file when cured. I believe K2000 and Emax series keyboards to have very similar if not the same case materials
Sent from Yahoo Mail on Android
From:"graham.hunter@... [emax]" <emax@yahoogroups.com>
Date:Fri, Jul 17, 2015 at 12:28 PM
Subject:[emax] Emax 2 Case Repair
Thanks!
2015-07-18 by krikor kouchian
Hi
I used miliput epoxy paste to repair my RZ1 case.
It works perfectly and the color is more grey than black which is perfect for the emax.
check the picts here:
best
K
http://www.krikor.fr
+33632199413
For Live&Dj bookings contact: cedric@...
2015-07-17 19:28 GMT+02:00 graham.hunter@... [emax] <emax@yahoogroups.com>:
Thanks!
