Re: [elektron] How do I get Support at Elektron? Reply
2004-07-05 by allen949@aol.com
I have a pattern that I like in MnM, I wish to be able to record the audio of that pattern into Cubase, and also record the MIDI data of each track into Cubase (so that I don't have to re-enter it manually). This way, I can layer additional sounds (triggered from the MIDI tracks) exactly in sync with my MnM pattern. I have set up Gobal so that Control Out 1 is set to "int + out" on keyboard, arp and sequencer. I have the audio routed to "3x stereo + AB mix" (though changeing this doesn't seem to have any effect on things). Control Out 2 is set to "out" for control and transport. Control In Tempo Sync is set to internal. Everything else is unchanged from factory defaults. When I set Cubase to accept MIDI data on any channel, it sees nothing. I am using a MidiSport 2X2 interface, which has served me well for years, and which routed the OS update just fine. However, when a MIDI device is connected to the MidiSport "IN" there is usually a flashing light corresponding to the connected channel (this lets me know that the interface is seeing the MIDI device). However, the "recognition" light never flashes when the MnM is attached from MIDI OUT to the interface, only when MIDI THRU is connected and I also have another keyboard connected to MnM MIDI IN. If I am just being really stupid and overlooking something simple, I apologize, but I have spent a lot of time trying to riddle this out, to no avail. I wouldn't feel so frustrated if I didn't like the MnM so much. I really don't want to stop using it, but I feel that something is missing if I can't do something like easily swap in an instrument for a couple of cycles in the middle of a song. Thank-you for paying attention to this frustration of mine. Sincerely, A [Non-text portions of this message have been removed]
