Elektron Musical Instruments
Index last updated: 2026-04-28 23:22 UTC
New Machinedrum: Can't change kits, parameters...
2004-05-26 by ruchmathias
Friends,
I just got the Machinedrum directly from Sweden. The joy was soon
over: I cannot change sounds or kits or anything...
I talked to the local assistant already, he told me to do the
factory reset. I did so, but nothing happened. Here's what's
happening (or what's not, so to say):
- I start the Machinedrum, it says KIT: INIT, AO1
- As stated in the manual, I chose another kit via KIT, move with
the arrow keys to another KIT, press ENTER and... still the same
sounds. I tried like 10 different kits, always the same sound.
- I cannot modify any parameter: SYTHESIS is active, BD chosen, I
push the BD button and change i.e. the pitch value: nothing
happens...
What's interesting: not every pad is connected to a sound. I don't
have a sound on pad 4,5,8,10,11,12.
Didn't do much more, since I cannot even change the individual
instrument sounds.
I guess this is a malfunction, since I acted as stated in the manual
and already talked to your Swiss contact. Or am I fundamentaly
missing something?
Need your help. Thanks in advance.
Mathias
Re: [elektron] New Machinedrum: Can't change kits, parameters...
2004-05-27 by Joe Melnyk
wow, this sucks!  sorry that your MD experience is going this bad so
far. it
gets better, I promise! :-)
I would suggest that you contact Elektron tech support for assistance.
it sounds
like something is majorly screwed in your MD.  but it also sounds like
it might
be something in your OS. so in the meantime, I would also suggest
downloading the
OS from their website and try installing that into your MD; it may not
be the
problem, but it's worth a shot at least.
good luck!
Joe
>  missing something?
