pitchbend monomachine
2004-05-25 by kvasimesis
Index last updated: 2026-04-28 23:22 UTC
i wasn't able to record "pitch bend" from ext controller-keyboard while in live-recording mode in tabletop monomachine. is it even possible? how does it work with the joystick on sfx-6?
2004-05-25 by Joe Melnyk
On May 25, 2004, at 2:35 AM, kvasimesis wrote: > i wasn't able to record "pitch bend" from ext controller-keyboard > while in live-recording mode in tabletop monomachine. is it even > possible? nope. > how does it work with the joystick on sfx-6? it doesn't. there's been a bit of discussion on this in the past. if I remember correctly, the pitch bend value range is too large to be recorded. however, you should be able to create a similar effect from the onboard MnM sounds by using the tune/pitch parameters (where applicable). Joe
2004-05-25 by tj297
i don't have my Mono yet but i've been thinking about this topic. perhaps i= t is possible to create a pitchbend with the parameter locks by engaging portamento and t= uning across two points. i don't know if it even has porto but i would imagine th= at would work if it did. still can't get my head around why it can't record stick movements. seems l= ike such a basic task. --- In elektron-users@yahoogroups.com, Joe Melnyk <jmelnyk@c...> wrote:
> On May 25, 2004, at 2:35 AM, kvasimesis wrote: > > > i wasn't able to record "pitch bend" from ext controller-keyboard > > while in live-recording mode in tabletop monomachine. is it even > > possible? > > nope. > > > how does it work with the joystick on sfx-6? > > it doesn't. there's been a bit of discussion on this in the past. > if I remember correctly, the pitch bend value range is too large to > be recorded. > > however, you should be able to create a similar effect from the > onboard MnM sounds by using the tune/pitch parameters (where > applicable). > > Joe
yeah.. there's actually quite many things on mono, that you can usually do very easily with most synthesizers on the market, you need to use LFOs or parameter locks.. and you end up with tons of parameters you automated... --- In elektron-users@yahoogroups.com, "tj297" <tj297@y...> wrote: > i don't have my Mono yet but i've been thinking about this topic. perhaps i= > t is possible > to create a pitchbend with the parameter locks by engaging portamento and t= > uning > across two points. i don't know if it even has porto but i would imagine th= > at would > work if it did. > > still can't get my head around why it can't record stick movements. seems l=
> ike such a > basic task. > > > > --- In elektron-users@yahoogroups.com, Joe Melnyk <jmelnyk@c...> wrote: > > On May 25, 2004, at 2:35 AM, kvasimesis wrote: > > > > > i wasn't able to record "pitch bend" from ext controller-keyboard > > > while in live-recording mode in tabletop monomachine. is it even > > > possible? > > > > nope. > > > > > how does it work with the joystick on sfx-6? > > > > it doesn't. there's been a bit of discussion on this in the past. > > if I remember correctly, the pitch bend value range is too large to > > be recorded. > > > > however, you should be able to create a similar effect from the > > onboard MnM sounds by using the tune/pitch parameters (where > > applicable). > > > > Joe
2004-05-26 by kvasimesis
> yeah.. there's actually quite many things on mono, that you can > usually do very easily with most synthesizers on the market, you need > to use LFOs or parameter locks.. and you end up with tons of > parameters you automated... like the machine is NOT velocity sensitive, not even played from an external controller... to name one thing. > --- In elektron-users@yahoogroups.com, "tj297" <tj297@y...> wrote: > > i don't have my Mono yet but i've been thinking about this topic. > perhaps i= > > t is possible > > to create a pitchbend with the parameter locks by engaging > portamento and t= > > uning > > across two points. i don't know if it even has porto but i would > imagine th= > > at would > > work if it did. > > > > still can't get my head around why it can't record stick movements. > seems l= > > ike such a > > basic task. > > > > > > > > --- In elektron-users@yahoogroups.com, Joe Melnyk <jmelnyk@c...> wrote: > > > On May 25, 2004, at 2:35 AM, kvasimesis wrote: > > > > > > > i wasn't able to record "pitch bend" from ext controller- keyboard > > > > while in live-recording mode in tabletop monomachine. is it even > > > > possible? > > > > > > nope. > > > > > > > how does it work with the joystick on sfx-6? > > > > > > it doesn't. there's been a bit of discussion on this in the past. > > > if I remember correctly, the pitch bend value range is too large to
> > > be recorded. > > > > > > however, you should be able to create a similar effect from the > > > onboard MnM sounds by using the tune/pitch parameters (where > > > applicable). > > > > > > Joe
2004-05-26 by Gene Schwartz
Yes, you can play it from an external controller.
From: "kvasimesis" <hugebass2@...> Reply-To: elektron-users@yahoogroups.com Date: Wed, 26 May 2004 11:47:52 -0000 To: elektron-users@yahoogroups.com Subject: Re: [elektron] pitchbend monomachine > yeah.. there's actually quite many things on mono, that you can > usually do very easily with most synthesizers on the market, you need > to use LFOs or parameter locks.. and you end up with tons of > parameters you automated... like the machine is NOT velocity sensitive, not even played from an external controller... to name one thing. > --- In elektron-users@yahoogroups.com, "tj297" <tj297@y...> wrote: > > i don't have my Mono yet but i've been thinking about this topic. > perhaps i= > > t is possible > > to create a pitchbend with the parameter locks by engaging > portamento and t= > > uning > > across two points. i don't know if it even has porto but i would > imagine th= > > at would > > work if it did. > > > > still can't get my head around why it can't record stick movements. > seems l= > > ike such a > > basic task. > > > > > > > > --- In elektron-users@yahoogroups.com, Joe Melnyk <jmelnyk@c...> wrote: > > > On May 25, 2004, at 2:35 AM, kvasimesis wrote: > > > > > > > i wasn't able to record "pitch bend" from ext controller- keyboard > > > > while in live-recording mode in tabletop monomachine. is it even > > > > possible? > > > > > > nope. > > > > > > > how does it work with the joystick on sfx-6? > > > > > > it doesn't. there's been a bit of discussion on this in the past. > > > if I remember correctly, the pitch bend value range is too large to > > > be recorded. > > > > > > however, you should be able to create a similar effect from the > > > onboard MnM sounds by using the tune/pitch parameters (where > > > applicable). > > > > > > Joe Yahoo! Groups Sponsor ADVERTISEMENT Yahoo! Groups Links To visit your group on the web, go to: http://groups.yahoo.com/group/elektron-users/ To unsubscribe from this group, send an email to: elektron-users-unsubscribe@yahoogroups.com <mailto:elektron-users-unsubscribe@yahoogroups.com?subject=Unsubscribe> Your use of Yahoo! Groups is subject to the Yahoo! Terms of Service <http://docs.yahoo.com/info/terms/> . [Non-text portions of this message have been removed]
Oops, you meant that it's not even velocity controlled from an external controller - misread it. Sorry.
2004-05-26 by Jeff Storm
a lot of old mono synths didn't have velocity control. Maybe they were going for that? I dunno. Does the keyboard transmit velocity data?
Sent: Wednesday, May 26, 2004 9:33 AM
need
> perhaps i=
> > t is possible
> portamento and t=
> > uning
> imagine th=
> > at would
> > work if it did.
movements.
> seems l=
> > ike such a
> > basic task.
keyboard
even
> > > > possible?
> > > nope.
past.
large to
> > > be recorded.
> > > applicable).
> > > Joe
Yahoo! Groups Links
ADVERTISEMENT
Yahoo! Groups Links
a.. To visit your group on the web, go to:
b.. To unsubscribe from this group, send an email to:
c.. Your use of Yahoo! Groups is subject to the Yahoo! Terms of Service.
[Non-text portions of this message have been removed]2004-05-26 by Andr00
The keyboard transmits velocity, of course. The Mono also responds to velocity. You assign key velocity to add to any parameter, on a per-machine basis. By default it is not assigned to anything. -Andrew D
On Wed, 26 May 2004 13:01:47 -0400, Jeff Storm <jeff@...> wrote: > a lot of old mono synths didn't have velocity control. Maybe they were > going for > that? I dunno. Does the keyboard transmit velocity data? > ----- Original Message ----- > From: Gene Schwartz > To: elektron-users@yahoogroups.com > Sent: Wednesday, May 26, 2004 9:33 AM > Subject: Re: [elektron] pitchbend monomachine > > Oops, you meant that it's not even velocity controlled from an external > controller - misread it. Sorry. > > From: "kvasimesis" <hugebass2@...> > Reply-To: elektron-users@yahoogroups.com > Date: Wed, 26 May 2004 11:47:52 -0000 > To: elektron-users@yahoogroups.com > Subject: Re: [elektron] pitchbend monomachine > > > >> yeah.. there's actually quite many things on mono, that you can >> usually do very easily with most synthesizers on the market, you > need >> to use LFOs or parameter locks.. and you end up with tons of >> parameters you automated... > > like the machine is NOT velocity sensitive, not even played from an > external controller... to name one thing. > >
2004-05-27 by kvasimesis
oh that's so true, how stupid of me! --- In elektron-users@yahoogroups.com, Andr00 <andr00@e...> wrote: > The keyboard transmits velocity, of course. The Mono also responds to > velocity. You assign key velocity to add to any parameter, on a > per-machine basis. By default it is not assigned to anything. > -Andrew D > > On Wed, 26 May 2004 13:01:47 -0400, Jeff Storm <jeff@j...> wrote: > > > a lot of old mono synths didn't have velocity control. Maybe they were > > going for > > that? I dunno. Does the keyboard transmit velocity data? > > ----- Original Message ----- > > From: Gene Schwartz > > To: elektron-users@yahoogroups.com > > Sent: Wednesday, May 26, 2004 9:33 AM > > Subject: Re: [elektron] pitchbend monomachine > > > > > Oops, you meant that it's not even velocity controlled from an external > > controller - misread it. Sorry. > > > > From: "kvasimesis" <hugebass2@s...> > > Reply-To: elektron-users@yahoogroups.com > > Date: Wed, 26 May 2004 11:47:52 -0000 > > To: elektron-users@yahoogroups.com > > Subject: Re: [elektron] pitchbend monomachine > > > > > > > >> yeah.. there's actually quite many things on mono, that you can > >> usually do very easily with most synthesizers on the market, you > > need > >> to use LFOs or parameter locks.. and you end up with tons of > >> parameters you automated... > > > > like the machine is NOT velocity sensitive, not even played from an
> > external controller... to name one thing. > > > >
