Elektron Musical Instruments
Index last updated: 2026-04-28 23:22 UTC
Re: [elektron] MD SPS-1 Timing Performance Issues
2007-04-05 by Scott
Hi David,
Following your testing method, here's the first 8 quarter notes' spacing data from my hardware sequencers.  I used a single track of hard-quantized uniform velocity and gated rim-shot samples.  Do my thoughts/comments make sense to you?
Elektron MD SPS-1 UW OS v1.33
22112 22017 22048 22113 22016 22049 22016 22113
max. differential: 95 samples
comments: somewhat uniform long/short variation pattern with a period of roughly every 1/2-2/3 measure
Korg EMX-1 latest OS
22001 22000 22100 21998 22100 22000 22100 22000
max. differential: 102 samples
comments: after the first two notes, the variation becomes uniform (i.e tight relative to its own timebase)
RS7000 latest OS
22051 22047 22050 22114 21984 22047 22050 22120
max. differential: 130 samples
comments: has a different short/long pattern with a period of roughly 1 measure
Roland MC-80 EX OS version unknown
21998 22060 22059 22070 22047 22060 22065 22069
max. differential: 62 samples
comments: after the first two notes, the variation minimizes resolves to a similar pattern as the RS7000, but with a much smaller variation magnitude of 23 samples (i.e tighter)
Conclusion: the MC-80 EX is the tightest of my hardware sequencers.  So, does anyone want to buy it?  ;-)
It's ironic that the most fun and interactive of these sequencing devices (MD and EMX) have the most clock variation from ideal, whereas the most structured and rigid box (MC-80 EX) is the "tightest".  Coincidence?
Finally - have you done any measurements of software VSTi hosts playing the quarter-note pattern in one computer, and using another computer to record the host's audio output?  Of course there are many more variables in SW, such as audio interface latency, the VSTi plug-in itself, the host, the OS, etc... but that's SW for you.  It would be interesting to see how SW stacks up against HW...
I have a feeling you might experience different results with rendered audio tracks within the host as opposed to recording the audio output on another computer/device.  My guess is that rendering would yield a more accurate output than a recording of the audio output.  Do you agree?
Scott
  To: elektron-users@yahoogroups.com
  Sent: Wednesday, April 04, 2007 3:42 AM
  Subject: [elektron] MD SPS-1 Timing Performance Issues
  Hi all - there is an interesting topic/thread regarding timing
  stability of the MD SPS-1 at the Elektron Users Forum if anyone feels
  like taking a look while the thread and interest is active.
  http://www.elektron-users.com/modules/newbb/viewtopic.php?
  topic_id=2155&viewmode=flat&order=ASC&start=0
  All the best - David
  www.innerclocksystems.com
2007-04-05 by Scott
BTW, make sure you place nice and don't disparage anyone or anything (hint) too much on that forum or you will run the risk of getting banned like I did.
2007-04-05 by innerclock2004
Hi Scott - thanks for the reply and the testing.
Give or take the odd sample - your MD tests are almost identical to
mine which is good and bad if you get my drift!
The RS I thought would do better so I'm glad I never bought one!
The MC-80EX is a surprise - I never tested tempo stability but they
all have Zip/Hard Drive Buffer/Midi Jam problems that were never
resolved so it always got the boat anchor in my book - shame really.
As far as VSTis and Computers go - I use them for word processing and
maybe a bit of 2 track editing. Oh and a paperweight now and again too!
Unless you work all under the hood of a computer which I refuse to do
because the real world is much more fun - sync/timing via crap
USB/Midi/Sloppy Windows drivers etc just doesn't cut it next to tight
hardware so I doubt I will get around to plug-ins.
Thanks again for the test and the interest Scott.
All the very best.
David
> RS7000 latest OS
roughly 1 measure
Coincidence?
> Thanks,
> Scott
>   ----- Original Message -----
>   From: innerclock2004
