Disklavier
Index last updated: 2026-04-28 23:20 UTC
Malfunctioning Mark III controller
2017-06-21 by daveproberts@...
After years of trouble-free use, my Mark III controller has suddenly crapped out. It might have been due to a power surge as the power went out last night and I had the piano plugged directly into a wall outlet instead of a surge protector.
The controller no longer plays CDs (the screen goes blank when the CD player light flashes) and it no longer plays the piano keys. It does still play floppies, which can be heard through the internal tone generator. But not on the default channel 1. I have to switch to channel 2 or another number for the left channel. If the right channel is changed to channel 1, the sound disappears. It seems like it still can record my playing, but it doesn't generate any tones on playback, not even when I switch to channel 2.
So for now I can still play tunes through the tone generator with the floppies and through my iPad by mapping the Sweet Midi Player channel 1 to channel 2. But my guess is that I'm out of luck for anything else -- unless anyone has suggestions.
I guess I'll have to live with it as is, or spend $1,500 for a DKC850, assuming they're still making them But my concern is that it might not even work if there's been some other damage to the key sensoring mechanism.
Anyone have any thoughts?
Re: Malfunctioning Mark III controller
Correction: I just checked and the piano is in fact plugged into a surge protector power strip. So I don't know what has caused the problem.
Re: [disklavier] Re: Malfunctioning Mark III controller
2017-06-21 by Spencer Chase
most "surge protectors" are garbage. at best they will suppress minor spikes and maybe do a little high frequency filtering. my power is much better after fighting with PG & E and finally getting the PUC on my side and getting the faulty distribution system fixed. PG & E actually spent millions to fix it and it is just like most places now. Before that I got massive surges (technically referred to as faults) so i did a lot of research into surge protectors. As i said, most are total garbage and do almost nothing at all.
Currently i have an industrial strength whole house protector installed (this is not the little thing you buy for a few hundred dollars, it is the real thing used to protect commercial installations and retails at over $2500 and i also have every sensitive device (pianos especially) plugged into decent surge protectors. But my power is really good now and i no longer have fires and explosions on a regular basis so this stuff is ll there but not as necessary as it was before.
Most "surge protectors" have a few little MOVs in them that can absorb a little bit of a surge under the right circumstances. One of the big problems is that they deteriorate over time as they are stressed by surges and nothing will tell you if they still have any ability to protect. The silly little OK LEDs mean nothing.
There is one line of surge protectors that is better than most and can offer a fair amount of protection. These are the devices made by Panamax and which are specified as "protect and disconnect" . Not all of their products offer this feature. They have a deadman relay that makes the connection to the line and if anything looks suspicious on the supply side such as high or low voltage, it disconnects the load from the line. This can result in some false disconnects and your computer might be shut off when it could have actually survived the power line strangeness. This might be the reason that not all of their products offer this feature. For something that i care about it is worth the risk of an occasional false shut down.
I have about 20 of these things and everything with electronics in it is plugged into one.This includes the refers, the microwave, the dishwasher, the heart lung machine (just kidding) I do not have the massive faults that i used to have so i could probably eliminate these things but they do no damage and who knows what might happen next week???
I have definitely had surges (faults) that would have destroyed my piano and other things if i did not have these surge protetors during the time i was having these problems. I had two fires caused by faults and many devices destroyed that could not easily be protected before i got my whole house (expensive) thingy. Just things like dimmers and remote control switches but at about $50 to $100 each, the do add up.
Best regards, Spencer Chase
67550-Bell Springs Rd.
Garberville, CA 95542 Postal service only.
Laytonville, CA 95454 UPS only.
21220 92nd Place W., Edmonds, WA 98020
Spencer@spencerserolls.com
Spencer@...
Spencer@...
http://www.spencerserolls.com
http://www.poodlex.com
(425) 791-0309
(707) 223-8212
------ Original Message ------
From: "daveproberts@sbcglobal.net [disklavier]" <disklavier@yahoogroups.com>
Sent: 6/20/2017 8:58:06 PM
Subject: [disklavier] Re: Malfunctioning Mark III controller
2017-06-21 by Bill Brandom
The DKC-850 will NOT solve your problems.
If there was a surge, you probably have a power supply problem. The first place to check are the fuses in the power supply.
You need to get your piano working BEFORE you upgrade to a DKC-850.
Bill
Love God. Love People. Make a difference.
On Jun 20, 2017, at 8:58 PM, daveproberts@... [disklavier] <disklavier@yahoogroups.com> wrote:
--9nlWnTS9ocNmxdhsK3FKVLWiM6a5jwOaA8HvrLV
Content-Type:  text/plain;  charset=utf-8
Content-Transfer-Encoding: base64
Content-Type:  text/html;  charset=utf-8
--9nlWnTS9ocNmxdhsK3FKVLWiM6a5jwOaA8HvrLV--
Update: A generous member of this group has offered to give me his Mark III controller, which he's no longer using, having upgraded to a model with a DKC850. That's very kind of him, what a great group this is. Hopefully, that will take care of the problem.
But the info on the inadequacy of most power strips has me concerned. If it was a power surge that caused this, it didn't affect anything else in the house and I've never had a problem before. So I'm not sure what to do short of investing in expensive power protection or pulling the plug on the piano when not using it.
2017-06-21 by Stephen Alston
It seems to me you wouldn’t want to use a power strip anyway. Rather, an Uninterruptible Power Supply (UPS) since you don’t want to disrupt write operations on the hard disk due to power interruptions. That scenario could possibly corrupt the hard disk.
Thoughts from the group? When should you replace a UPS? Mine is 10 years old.
2017-06-21 by Carol Beigel
Have you tried unplugging the unit and then plugging it back into the wall outlet - not a surge protector?  Is the wall outlet grounded - as in a 3-prong outlet?  Is this a grand piano?  Sometimes Mark III Grand piano Disklaviers wake up thinking they are uprights.  What exactly does the opening screen say?  Is the volume knob on the left box under the keys turned up?  Is the keyboard turned on - as is keyboard out turned on?
MarkIII Disklaviers have always been my favorite, but sometimes they can be strange little beasts.  Also check the fuses.  Do you have a Disklavier technician?
I personally keep my Disklavier unplugged from the wall until I am ready to use it.  Best surge protection I know of !
Carol Beigel
> On Jun 21, 2017, at 4:09 PM, daveproberts@... [disklavier] <disklavier@yahoogroups.com> wrote:
2017-06-22 by Dave Roberts
Thanks, Carol, for those questions/suggestions. I've tried some of them, including a factory reset, and will now try the others. If anything works, I'll report back.
Dave
2017-06-22 by tnmshd@...
I recommend you to enter test mode and check history.
Push L,R key with power switch.
Forward with Y key.
Error history display.
Push play key
Check Error history message.
Push play key.
End.
Did you see the message?
Piano power off thermo / PWM over.
2017-06-22 by Carol Beigel
Yes, this a very good thing to check. After entering test mode there will be a screen that shows model, version, etc.  Use the Yes/No button to set the piano type and the Record button to select whether or not the instrument is a silent mode ("S")
The display looks something like this:
V4.20  Mar 23 2001
55RCD  ENG  REC. GP. DB50
This piano would have v4.20 software, a 55RCD control box, English language, have Record capability, be a grand piano, and have a built-in daughter board tone generator DB51
Carol Beigel
> On Jun 22, 2017, at 5:35 AM, tnmshd@... [disklavier] <disklavier@yahoogroups.com> wrote:
> Forward with Y key.
> Push play key
> Push play key.
> End.
2017-06-23 by daveproberts@...
I went into test mode, but there was no error history display. It just reads "CONTROL SHEET."
I went through the tests, but they did not reveal anything and had no effect.
I did find the model data, which is similar to that listed by Carol.
I think I'm out of luck with this unit. Hopefully, the replacement controller will bring my C2 back to life.
2017-06-23 by Bill Brandom
Stop!
Let's review the issues. Re-tell me what is specifically the problem.
Bill
On Jun 22, 2017, at 6:47 PM, daveproberts@... [disklavier] <disklavier@yahoogroups.com> wrote:
2017-06-25 by tnmshd@...
Could you play by yourself in silent mode ?
Could you use damper and other pedals in silent mode?
or Enter test mode and check sensor sheet test
Sensor test sheet -play-play
key depth /hammer,,,,
If you could play silent mode or work sensor test. then DKC55RCD is Ok.
Piano drive power voltage is gone.
Power Unit or pedal drive or key drive or pk-ctl has problem.
2017-06-26 by Dave Roberts
No, it doesn't play in Silent Mode and the sensor sheet test is not one of the options that comes up when I enter test mode.
2017-06-26 by Bill Brandom
Dave,
Not hearing anything in Silent mode and not seeing Sensor Sheet, tells me that either one of the Sensor boards (sheets) is defective, or the key/hammer sensing system has been disconnected.
If you record a song playing the right pedal and then the left pedal, and then save the file, during song playback do the pedals play back?
Bill
On Jun 25, 2017, at 10:52 PM, Dave Roberts daveproberts@sbcglobal.net [disklavier] <disklavier@yahoogroups.com> wrote:
2017-06-26 by tnmshd@...
please see the attached file and enter the Test mode and check control ,sensor sheet and error log again .
but never do the RAM Rom clear (flash eep,,,)
2017-06-27 by Bill Brandom
Ok Dave,
It sounds like the Sensor board on the treble end of the action stack is bad, or the connections from the pedals key and hammers are bad.
Bill
On Jun 26, 2017, at 5:44 PM, daveproberts@... [disklavier] <disklavier@yahoogroups.com> wrote:
I'm sorry, I don't see the attachment.
Darren,
Before you replace the Sensor  board, if you do a Record/Playback test, do ANY keys play back.
Record/Playback test involves playing each key chromatically during record mode. Do ANY keys play back?
Bill
On Jun 26, 2017, at 10:49 PM, Bill Brandom billbrando@... [disklavier] <disklavier@yahoogroups.com> wrote:
Ok Dave,
Bill
2017-06-28 by daveproberts@...
I can't enter the PK CTL SHEET test mode -- the screen goes blank. I only see CONTROL SHEET and DSP SHEET test screens.
No, Bill, none of the keys play back when I record.
I'm hoping the problem is with the control unit. A generous member of this user group is sending me a replacement. I'll let you know if it does the trick.
2017-06-28 by Bill Brandom
Dave,
This is new information. PK CTRL board controls pedal and keys for both record and playback functions. If you can't "see" it, the board has failed or there is a connection issue between the PK CTRL board and the rest of the system.
In an earlier post I think you stated that you could not access the SENSOR board (sheet). Is that correct?
Bill
On Jun 27, 2017, at 9:19 PM, daveproberts@... [disklavier] <disklavier@yahoogroups.com> wrote:
2017-06-28 by tnmshd@...
Please disconnect and connect with piano and PPC55RCD again.
Please enter Test mode again and check CTRL sheet again.
CTRL sheet -- foward -- Ver.piano mode check again following item.
V4.10 Apr 01 2000
55RCD|ENG|REC|GP|S|DB51
If you see difference item then push play and enter edit mode and edit item.
If you see the same display then PPC55RCD is OK.
PKCTL/Power unit/ sensor /pedal has problem.
55RCD=controller model
ENG=language
REC=recording model
GP=piano type
S=Silent piano
DB51=TG model
Let's try again!
Re: [disklavier] Malfunctioning Mark III controller
2017-06-28 by George F. Litterst
Good afternoon, everyone.
If you are disconnecting your control unit from the piano, please be sure that the piano has been completely powered down!
PianoBench
On Jun 28, 2017, at 5:48 AM, tnmshd@... [disklavier] <disklavier@yahoogroups.com> wrote:
V4.10 Apr 01 2000
ENG=language
REC=recording model
GP=piano type
S=Silent piano
DB51=TG model
Let's try again!
2017-07-29 by daveproberts@...
UPDATE:
I want to thank everyone for their help and advice on my problem. After one of the generous members of this group sent me his no-longer-needed Mark III controller, I plugged it in and experienced the same problem. Which, of course, made me realize the controller is not the problem.
It turns out that the cable connection from the piano to the controller has three prongs missing. That should have been the first thing I checked, but for some reason it never occurred to me. So the controller is receiving enough data from the remaining prongs to turn it on and operate some functions, but not enough to work data properly.
My question now is: How do I replace this cable? The other end goes into the amplifier. Is this a simple matter of opening up the amplifier housing, pulling out the bad cable and inserting a good one? Or is it more involved and I should hire a Disklavier technician or electrician?
Dave
2017-08-01 by daveproberts@...
Bill,
It looks like you were right. Martin Arroyo, the tech guru at the Yamaha Service Department, believes it's a problem with the PK Control board based on the blank screen at PK CTL SHEET test mode. Unfortunately, it's going to cost nearly $1,000 to replace it.
Thanks again for your help.
Dave
2017-08-01 by Bill Brandom
Dave,
Martin is an electronics expert. His information is valid. See if you can find a Disklavier (or other piano technician) to call about buying the PK CTRL board. They should be able to get it at a better  price and they may pass those savings to you.
Bill
On Jul 31, 2017, at 8:10 PM, daveproberts@... [disklavier] <disklavier@yahoogroups.com> wrote:
Bill,
Dave
2017-08-01 by Donal Galvin
Dave
I had a problem with my mark 3 a few years back. When you wiggles the cable on the treble end do the red Light's come on and off ? A board had to be replaced as it was an intermittent connection problem.
> On 29 Jul 2017, at 21:31, daveproberts@... [disklavier] <disklavier@yahoogroups.com> wrote:
> UPDATE:
> Dave
2019-09-29 by Gary Hobbs
I have a Mark 3 .  A few months back it would not play my floppies in the midi form so I changed them to the FIL file and it worked great.My current problem is when I insert a floppy - it says the disc is not formatted and it will not play.
I have pressed a button on the controller and changed something or is it the controller.  Any help would be appreciated.
Thank You
- Gary L. Hobbs ghobbs_nhs@...
    On Tuesday, August 1, 2017, 03:29:23 AM EDT, Donal Galvin discodonal@... [disklavier] <disklavier@yahoogroups.com> wrote:
