Datacolor User to User Support Group.
Index last updated: 2026-04-28 23:18 UTC
Moving from Spyder3Pro to Elite
2009-07-11 by tlbepson
I decided to upgrade from the Spyder3Pro to Elite and I have a quick question.
I figured that I would want to uninstall Pro before installing Elite and  Datacolor support confirmed that I should but later, I realized I should have asked if I should move the Spyder3Utility out of Startup (running WinXP), reboot (Spyder3Utility would not run) and then do the Pro uninstall?
In other words, would I have a  problem uninstalling Spyder3Pro if the Spyder3Utility has been loaded/is running?
By they way, Datacolor support was really excellent because while their normal procedure for an upgrade like this is to call to get the payment info, I have a hearing loss which makes the phone very difficult for me to use and they were very accomodating and came up with an alternate approach so I did not have to use the phone.
Terrie
http://tlbtlb.com/
tlbtlb@...
Re: [datacolor_group] Moving from Spyder3Pro to Elite
2009-07-12 by Cdtobie
I'd say that just quitting the Utility before the uninstall should be
sufficient.
C. D. Tobie
Global Product Technology Mngr.
Digital Imaging & Home Theater
Datacolor.com
CDTobie@...
> question.
> Terrie
> http://tlbtlb.com/
> tlbtlb@...
Re: Moving from Spyder3Pro to Elite
2009-07-12 by tlbepson
>><CDTobie@...>: I'd say that just quitting the Utility before the uninstall should be sufficient.
Ok...
Thanks!
Terrie
http://tlbtlb.com/
tlbtlb@mail.com
Spyder3Print profiles disappear randomly?
2009-07-13 by Bob Petruska
I'm using Windows Vista SP2 and when using my photo editing programs
Nikon NX2 or Photoshop CS4 and about to print, the program crashes
sometimes.  When it does just my Spyder3Print  ICC profiles disappear
from the windows/system32/spool/drivers/color location.  All other
ICC profile remain intact.  I was lucky to retrieve these lost
profiles (10 profiles) from a backup and saved them to a disc to use
each time this strange thing happens.  This has taken place a few
times over the last few months.
I can see an application crashing, but to permanently erase the
profiles from the windows profile directory just doesn't seem right.
Any suggestions?
Tanks,
Bob P.
2009-07-13 by Rollin
As someone else with hearing loss, I want to encourage all support groups to provide easy ways to get support WITHOUT having to use the telephone.  Since Datacolor Support apparently does, then let me simply say thank you and keep up the good work. That, along with the great support provided via this forum, help make the Datacolor products my choice for color management.
Rollin Hill
Re: [datacolor_group] Spyder3Print profiles disappear randomly?
2009-07-13 by C D Tobie
> Any suggestions?
Not sure you are lucky to save profiles that are crashing your
computer. If, for some reason, a profile or more than one profile,
become corrupted, usually due to disk errors, then you should delete
it, (ideally delete all profiles except the required sRGB one), and
start over. Starting over doesn't take long, it just means reprofiling
your displays, which you should do every month anyways, and rebuilding
any printer profiles from the measurement set that they were built
from initially. On the Mac you can check that profiles are okay using
the ColorSync Profile Tool, but there is no OS-provided equivalent
under Windows.
Oh, and keep good backups of your data, as you may be seeing early
signs of disk issues...
C. David Tobie
Global Product Technology Manager
CDTobie@...
Re: [datacolor_group] Re: Moving from Spyder3Pro to Elite
We are also working on making the patch reading process in
Spyder3Print as flexible as possible; sound cues are still important,
but giving as many types of cues and indicators as possible, so that
the process works for as many people as possible is the goal...
C. David Tobie
CDTobie@...
Re: [datacolor_group] Spyder3Print profiles disappear randomly? [1 Attachment]
My backup printer profiles are not corrupt, they are from a total back up made a few days after the profiles were initially made months ago.
My drives are fine, all 5 of them, in a raid configuration.
My display profile is updated once a month and not an issue here.
Maybe I wasn't too clear in my initial post as sometimes I just don't describe the problems correctly.
Only the "Spyder3Print ICC" profiles disappear, all my other custom profiles wether they are display, printer (downloaded canned profiles), etc. stay intact in the same windows folder.
I happens with both Nikon Capture NX2 and Photoshop CS4. I can run weeks without any problems, do some printing in a session and then the hang, relaunch the program instantly, no Spyder profiles; reboot, no Spyder profiles; restore the system to a day earlier, no Spyder profiles.
The strangest issue here is why would it be so selective to Spyder profiles and not the other printer profiles???
I'm asking on this forum as I was hoping someone may suggest why just the "Spyder profiles" are affected.
At 09:41 AM 7/13/2009, you wrote:
[ Attachment(s) from C D Tobie included below]
>; Nikon NX2 or Photoshop CS4 and about to print, the program crashes
> Any suggestions?
under Windows.
C. David Tobie
CDTobie@...
Datacolor
www.datacolor.com/Spyder3
2009-07-13 by David Miller
> months ago.
> Spyder profiles.
They're specifically tagged so that they can be identified as
Spyder3Print
profiles, so because of this: technically, it's possible to "screen" or
"filter" them and have them identified separately from other printer
profiles.
It's possible (although I can't image why) for a piece of software to
search specifically for Spyder3Print profiles and to delete them, while
leaving other printer profiles untouched.
Also:
Do you now (or have you had, in the past) any other 3rd party color
management
software installed on your system? What I -have- seen in the past is
other
color management software attempt to modify Photoshop's internal
preferences/saved
state for printer profiles and in the process: cause custom printer
profiles to
disappear from Photoshop's pop menus; and then crash. This was
specifically on
OSX; I didn't use this 3rd party software on Windows; but at the time,
issues with Photoshop were severe enough for me to make sure that I
uninstalled
the software to get Photoshop's stability and use of Spyder3Print
profiles back
again. (and since then, I haven't reinstalled that software, or later
versions
of it that may have fixed this).
However: what I'm describing doesn't fit your situation exactly. The
part about
Photoshop crashing, and custom printer profiles not appearing in
Photoshop, does;
but the part about the printer profiles themselves -physically
disappearing
from the system- does not.
David Miller
Senior Software Developer, Digital Color Solutions
Datacolor
2009-07-16 by Bob Petruska
Dave, thanks for the reply!
I started with a completely clean system, new clean hard drives.
The only printer calibration software installed is Spyder3Print. My monitor uses NEC's Spectraview II along with an Eye One Display Two calibrator. I only use either Nikon's Capture NX2 or Photoshop CS4 for photo editing and printing. No other color managed software is loaded except the FireFox web browser.
I have ran registry cleaners to see if that would help and so far not, but nothing has gone wrong in 5 days of heavy editing and printing, maybe it just fixed itself as windows seems to do all these years. Who knows what all these windows updates do right and wrong.
I'll post again if if it crashes and removes all the Spyder profiles....
Bob P.
> months ago.
>; Maybe I wasn't too clear in my initial post as sometimes I just
>; weeks without any problems, do some printing in a session and then
> Spyder profiles.
Spyder3Print
profiles.
Also:
management
other
preferences/saved
profiles to
specifically on
uninstalled
profiles back
versions
part about
Photoshop, does;
disappearing
David Miller
Datacolor
