Datacolor User to User Support Group.
Index last updated: 2026-04-28 23:18 UTC
Profiling epson color laser
2008-06-27 by ferdylau
I'm trying to profile my epson c2800 color laser. Unlike my epson
inkjet r1800 which I can totally disable the color managment. For
c2800, I can select [no color adjustment] under [color control],
however, there is an option where I can choose 1.5/1.8/2.2 gamma value.
The result can be very much different. Somebody suggests me to choose
[icm]. Which is the proper way to do it? Tks
RE: [colorvision_group] Profiling epson color laser
2008-06-27 by LAURIE
On most Epson printer driver user interfaces, the selection of "no color
adjustment" turns all color management off; in doing so, it also may turn
off the gamma adjustment as well depending on the particular printer driver.
The gamma adjustment traditionally was a way of adjusting for ink spread on
the paper in offset press printing, which depended on the ink and paper
being used; now it tends to refer to the location of mid gray on the
grayscale range of the display or print with respect to monitor displays and
inkjet printing.  Thus, the display or print will turn out lighter or darker
depending on the gamma setting.
To use a specific single, custom, or third party ICM color device profile
for a specific ink/toner and paper combination (or in some cases a set of
such combinations) from within the printer driver where you are letting the
printer do the color management, you need to have (1) the correct ICM color
profile for the printer/paper/ink or toner installed in the appropriate
location (i.e., folder) for your computer's operating system, (2) the
printer driver set to the ICM setting with under some printer drivers the
correct profile option selected from those listed in the ICM drop down box,
and (3) the color management control turned off in the image editing program
(such as Photoshop) or another application turned off so as to avoid double
color management.
If you are using Photoshop, Elements, or some other image editing program
that supports color management and allows one to control it from the
application itself rather than from the printer driver, it is typically
preferable to allow the application to control color management rather than
the printer driver or operating system.  To do this, one typically turns the
color management off  in the printer driver by selecting "no color
adjustment" and turning on the color management in the image editing program
where one would select the color profile to use for the printer.
[mailto:colorvision_group@yahoogroups.com] On Behalf Of ferdylau
Sent: Friday, June 27, 2008 7:37 AM
To: colorvision_group@yahoogroups.com
Subject: [colorvision_group] Profiling epson color laser
Re: Profiling epson color laser
2008-07-02 by Mark Godfrey
Do you have a choice of an RGB driver as well as PostScript CMYK for
the Epson c2800 color laser ?
Mark
2008-07-02 by ferdylau
It is not a Postscript printer, so I don't have a choice.
The color gamut of the 2 profiles created by the above methods are too
small(I compare them with hp p1215 color laser & CMYK). At the
beginning, I guess it might be the nature of the printer, however, when
I check its canned profile, it covers SRGB! Therefore, I guess I've got
something wrong in printing the 729 color patches.
Inside the printer driver, under the color management section, I've the
following selections :
- color adjustment (I can choose [no color adjustment] option which
disable CMY, brightness, satur adjustment but allow me to adjust gamma
value)
- PhotoEnhance
- ICM (disable all adj even gamma value)
- sRGB (disable all adj even gamma value)
Any suggestion? Rgds!
Re: [colorvision_group] Re: Profiling epson color laser
2008-07-02 by CDTobie@aol.com
In a message dated 7/2/08 2:10:58 AM, ferdylau@... writes:
That simplifies life...
The "raw" color gamut of the printer is shown in the printed target... if you've used settings that actually get "raw" output. So you can see the gamut right there, before you even measure or build a profile...
however, when
I assume that you mean by this that you get brighter color from the canned profile than from a custom profile... definately an issue with your settings then...
value)
- PhotoEnhance
You don't note which you have tried. You should be printing your target (as well as your final prints) with the Color Adjustment: No Color Adjustment setting selected.
C. David Tobie
WW Product Technology Manager
Digital Imaging & Home Theater
Datacolor
CDTobie@...
www.datacolor.com/Spyder3
Gas prices getting you down? Search AOL Autos for fuel-efficient used cars.
(http://autos.aol.com/used?ncid=aolaut00050000000007)
How complicate to profile a PostScript color laser? In fact, I need
to profile a Hp PS color laser cp3505 & I'm still finding how to
disable the color management.
target... if
see the gamut
I don't quite get what you means here?
the canned
your settings
> then...
I use [wincolor] utility to compare them
target (as
Adjustment
> setting selected.
I select Color Adjustment w/ no color adjustment & gamma = 2.2.
If you think the color adj is the right way to go, the created
profile with extremely small color gamut (get too much gamut warning
when soft-proof a CMYK test image, as compared to Hp color laser)
should be correct. I just can't understand why the gamut of the
canned profile has the same size as sRGB. Rgds!
In a message dated 7/2/08 2:33:05 PM, ferdylau@... writes:
Please analyze your profile by printing the SpyderProof Matrix image from SpyderProof, then print it again from Photoshop (in the second instance by using the Matrix image in the Test Image folder in our application's folder). The two should have the same gamut if you are configuring your Photoshop printing correctly. Use Saturation Intent, no Black Point Compensation in Photoshop, and Saturation intent in SpyderProof. Then, once these two match, compare them to a print made through your canned profile of the same image. Compare gamuts not with software tools, but by comparing how bright the most saturated colors in the Matrix test image are. Are they more saturated in the canned profile image? Then there is something wrong with how your profiling targets are being printed (limiting the available gamut for custom profiling), or our colors would be just as saturated, or a bit more so.
If our results are as bright or brighter than the canned profile, then the issue is with your software profile comparison methods. Do not trust gamut comparison tools, they don't show you the colors, they just tell you what the profile is telling them, and it may not be telling the truth. The colors are the ultimate test, not some software analysis.
C. David Tobie
Datacolor
CDTobie@...
