Rhodes Chroma Polaris group photo
Archive for chromapolaris.
Index last updated: 2026-03-30 01:08 UTC
New to the Board
New to the Board
2013-10-10 by <c.puidokas@...>
Hi Everyone!
How are you doing?  I just joined this board in an effort to have my Chroma Polaris be something other than a heavy paperweight.
I'm trying to diagnose the problems that my Polaris is showing.
So far I have done the following:
~ Plugged it in and tried playing a few notes - there was sound with a few keys, but it only registered the same note each time and on different keys and constantly alternating keys.  Some of the slider controls affected the sound (Attack, release, and decay), but others were unresponsive.
~ I then attempted to run diagnostics using the lower function and program select buttons.  However, I was unable to engage the lower function LED rendering a diagnostic scan impossible (at least from what I can understand).
~ When I turned the Polaris off and on again different sets of LED's were illuminated
My question is: could this be symptomatic of a dead battery/erased memory requiring a new set of batteries and MIDI sysex dump, or something much more complicated?
If anyone has any advise OR just wants to buy this broken synth from me to fix it themselves contact me.
Chris
Re: [chromapolaris] New to the Board
2013-10-10 by John Koumoutseas
I would first check what typical membrane switch problem you can read about it in previous posts in this group
On Oct 10, 2013 3:08 PM, <c.puidokas@...> wrote:
Hi Everyone!
Chris
2013-10-10 by w.james.meagher@...
Chances are your ribbon cables have gone (what lets all buttons and sliders communicate with the CPU).
You can fix (if you're handy), or purchase replacements for about $200 from a guy on this list who's name I eluding me at the moment (but I'm sure he'll chime in promptly). I recommend the replacements - they'll prolong the life of your Polaris greatly.
If you want to try the fix let me know and I'll send you a link to a video on how to do it. Involves some basic soldering, etc.
On 2013-10-10, at 14:08, <c.puidokas@...> wrote:
Hi Everyone!
Chris
2013-10-10 by klosmon
Hello-
It's possible to work out some of this yourself;  it requires some patience, some attention and much reading.
The service manual tells you a lot about the instrument;  your main goal should be to track down existing problems without causing any new ones.
To do this, you have to understand some things about this particular instrument;  for example, many of the operating system parameters are memory-based -- if it loses memory, it's not just the patch information, but the envelope & VCA offsets, MIDI settings, etc.  Restoring this is more than just doing a patch reload;  there are twenty or thirty key-presses and slider adjustments, which are detailed in the manual.
And, of course, this all depends on the membrane buttons being fully functional;  if they're not, you have to address that issue before doing anything else.
~G
On 10/10/2013 12:08 PM, c.puidokas@... wrote:
Hi Everyone!
Chris
2013-10-10 by Karl Durland
Something similar happened to mine. I replaced the batteries, trimmed back the ribbon wires so they responded, and did a hard reset which erased all the sounds and brought it back to it's basics. I then reloaded the sound banks from the Rhodes Chroma site. It has worked like a gem for 3 years now
-Karl
Sent from Yahoo! Mail on Android
To: chromapolaris@yahoogroups.com <chromapolaris@yahoogroups.com>;
Cc: <chromapolaris@yahoogroups.com>;
Subject: Re: [chromapolaris] New to the Board
Sent: Thu, Oct 10, 2013 7:19:10 PM
Hi Everyone!
Chris
RE: New to the Board
2013-10-10 by <wasteking1@...>
i agree with most of  what everyone says----
1.read the service manual  --
2. do a hard reset if controls work --this can cure some odd issues--but also clears the memory.
3. if controls dont work--and LEDs dont light up , particularly in rows --- check to see if brittle ribbon wires are broken-- this could mean the  $200 new  membrane panels. but be thankful they exist at all.
4. if individual keys dont sound  you probably have to clean the key contacts---  a slow but important process--- and there are 61 of them. all it takes is alcohol and q tips
-Karl
Hi Everyone!
Chris
