CGS 29 Wave multiplier Ver 2.2 Self oscillating
2013-06-25 by adematteo
2013-06-25 by cg_synth
>Hi guys,multiplier is oscillating and i can hear it from the power supply ?
>I just switched my power supply for a new case i made and now my wave
>using and all the wiring is the same exact wiring i was using in the other
>The power supply i'm using is the same model as the previous one i was
>appreciated !
>Not sure were to begin on this one so as always any ideas are greatly
>_______________________________________________________________________
>Thanks, Tony
>The CGS Modular Synth home page: http://www.cgs.synth.net/
>Yahoo! Groups Links
--- In cgs_synth@yahoogroups.com, sasami@... wrote:
> Sounds like the PSU may be overloaded and/or faulty.
> >Hi guys,
> case.
> appreciated !
> >Thanks, Tony
> >Yahoo! Groups Links
> Ken Stone sasami@... otherunicorn@...
> Modular Synth PCBs for sale <http://www.cgs.synth.net/>
>Thanks Ken, luckily i have a few more i can swap out.the only thing plugged in.When i plug in the rest of the bog panel
>I am getting correct voltages and the wave mult is doing it even when it's
>--- In cgs_synth@yahoogroups.com, sasami@... wrote:_______________________________________________________________________
>> >Hi guys,
>> case.
>> appreciated !
>> >Thanks, Tony
>> >Yahoo! Groups Links
>Yahoo! Groups Links
2013-06-26 by adematteo
> everything works as it should.
> Odd!
> >> >Hi guys,
> >> case.
> >> appreciated !
> >> >Thanks, Tony
> >> >Yahoo! Groups Links
> >> Ken Stone sasami@ otherunicorn@
> >Yahoo! Groups Links
2013-06-26 by cg_synth
>Well changing out the power supply seemed to do it.I'd guess it's kicking into current limit due to an incorrectly set trimmer,
>Do you have any ideas as to what would have gone bad on the other supply ?
> or a failed electro in the smoothing section.
> Ken
