1973 VCF - dc offset
2013-05-01 by goldencardigan
Hi all,
I've just finished building the serge filter and while everything looks and sounds like it is working correctly, I have noticed a bit of dc offset on the lowpass output. With no input signal, the dc voltage swings between +4v through 0v and back to +1v as I turn the cutoff knob.
It appears that the offset would not normally be this high, but I have installed the resonance mode, including using the buffer stages to compesate for the gain loss.
The offset disappears when I turn on the low freq mode.
I'm just not sure if this is normal behavior for the circuit or if I should be chasing a fault. I could of cause add a dc blocking cap to the output, but this would kill the low freq mode.
Has anyone else experienced this?
Cheers
Dean
Cheers
Dean
