>Ok, well my different manufacturer theory just went out the window.I popped
in 2 more lm3900's from the same manufacturer of the ones i had in that
didn't lock up my system and now the new ones are locking the system up.
>I am measuring 330 ohm resistance between pin 3 (gnd ?) and pin 14(-v)
>but only when the power is connected to the bus (unpowered) when i
disconnect it from the bus it goes open.
>This would leave me to believe that there's a short on my bus but all other
modules work fine until i connect this one ? And i'm not finding any shorts
when inspecting the bus.
>This ones really throwing me for a loop,can't wait to figure out what i did.
>--- In cgs_synth@yahoogroups.com, "adematteo" <adematteo@...> wrote:
>> Thanks Ken, All the correct voltages are going to the correct pins (-15v
to pin 7 +15v to pin 14) I may have put the 3900 that burned up in backwards ?
>> I checked all the component values and diode orientations this morning.I
still have to go through and check continuity throughout the circuit.
>> I've noticed both sections outputs exhibit the same behavior which is a
negative offset around -6v with nothing feeding the inputs.I checked pin 9
in the stepped section and if i feed a slow ramp and clock the sample input
i get a varying voltage between -6 and -13v but always stays in that range.
>> --- In cgs_synth@yahoogroups.com, sasami@ wrote:
>> > Also check you don't have your power rails swapped about.
>> > If you have used CA3401 instead of a lm3900, and it's seeing 30V it will go
>> > pop too, as they are only good for 15V rails, unlike the lm3900.
>> > >Hey guys, I just put together the SSG and it's not working so i tried to
>> > switch out the lm3900's after giving the board some continuity testing and
>> > looking over the board briefly, i still need to do a lot more
>> > troubleshooting but what i wanted to ask about was this,
>> > >when i switched the lm3900's out it froze my system up as if there was a
>> > short in the power supply.I did some tests to see but couldn't find a short
>> > anywhere so i put the old ones back in and system powered back on fine so i
>> > switched them out with brand new ones i had and it cooked them within
>> > seconds of powering up.
>> > >Like i said i still have a bunch of leg work to do to figure out why it's
>> > not working but am confused that some of the lm3900's would create what
>> > appears to be a short and the others seem to have no effect ?
>> > >Thanks, Tony
>> > >The CGS Modular Synth home page: http://www.cgs.synth.net/
>> > >Yahoo! Groups Links
>> > _______________________________________________________________________
>> > Ken Stone sasami@ otherunicorn@
>> > Modular Synth PCBs for sale <http://www.cgs.synth.net/>
>> > Australian Miniature Horses & Ponies <http://www.blaze.net.au/~sasami/>
>Yahoo! Groups Links
Ken Stone
sasami@... otherunicorn@...
