Cgs synth
keyboard
keyboard
2008-12-06 by waynerdlance
hey just wondering if anyone knows of a source for compatible keybaord assemblies for use
with the keyboard controller. im looking for something new (dont really want to dissect other
keyboards) any leads would be greatly appreciated.
Thanks Lance Iden
Re: keyboard
2008-12-06 by x24holsey
use
other
> Thanks Lance Iden
It feels like you might be looking for some of the more DIY switch assemblies to make a
small touch keyboard/button so have a look at the Doepfer site.
http://www.doepfer.de/home_e.htm
Doepfer sell plenty of DIY esoterica components in addition to real Fatar keyboard manuals
with plug-in sub-modules. Specific to what you mention above, they do have an 8x8 switch
matrix: CTM64 button board , that might be along the lines of what you need.
Re: keyboard
im actually looking for a keyboard that would be compatible with the mfos 1v/oct
keyboard controller pcb. ive seen the fatar keyboards on the doepfer site but i cant find a
schematic for the actual outputs of the keyboard. im looking for a single buss keyboard? i
dont really want to go the keyboard/midi/cv route for simplicities sake.
Thanks Lance Iden
--- In cgs_synth@yahoogroups.com, "x24holsey" <waveguide@...> wrote:
for
> use
dissect
> other
> > Thanks Lance Iden
manuals
switch
Re: keyboard
Lance,
Since we're on the cgs-synth mail group I thought you were referring to Ken's small mini
keyboard project board. Your verbage suggested the MFOS board mind you.
You used to be able to buy when Pratt-Read was the keyboard manual supplier to the
planet, such an item. Most I am aware of are Midi. You might cannibalize an otherwise
written off vintage synth for cheap, if you dare and salvage the keyboard assembly.
Not that much of a service tech to point you at modern sources of any suitable "OEM"
keyboard assembly that isn't midi'd out already.
Otherwise you might find simple switches of some kind for a eclectic DIY touch keyboard
which appeals to me somehow, ... one day. Maybe someone else listening can be more
helpful.
a
i
> Thanks Lance Iden
assemblies
> for
> > use
> dissect
> > other
> > > Thanks Lance Iden
a
> manuals
> switch
Re: keyboard
i actually posted on a couple forums. now that i read the first post i wasnt to specific.
thanks for your input and im curious what the actuall switch mechanism.s consist of on a
midi keyboard. maybe it could be adapted. anyways anyone with a schematic or a
password to dowload a schematic/mechanical design from the FATAR site would be
awesome.
Thanks Lance
> Lance,
mini
keyboard
> helpful.
find
> a
keyboard?
> i
> > Thanks Lance Iden
> assemblies
> > for
> > > use
> > dissect
> > > other
> > > > Thanks Lance Iden
make
> a
> > manuals
8x8
> > switch
Re: keyboard
awesome.
Thanks Lance
> Lance,
mini
keyboard
> helpful.
find
> a
keyboard?
> i
> > Thanks Lance Iden
> assemblies
> > for
> > > use
> > dissect
> > > other
> > > > Thanks Lance Iden
make
> a
> > manuals
8x8
> > switch
Re: keyboard
Doepfer posts the schematic of the internal workings of the Fatar assembly. Not
complicated but plenty of parallel switch closures with diodes from the 2x61 notes shown.
The system is scanning all the contacts looking for closure of each specific switch pair
which have a midi note mapped to them inside the Doepfer sub assembly/controller. The
difference between this digital-kbd and the analogue type of keyboard you want is the
lack of the resistor ladder to furnish the change of 1volt/octave change of output from a
common pitch bus.
If you wanted to butcher such a device, you are on your own, but one might think you
could replace the diodes-warranty void- with suitable resistors to constitute the required
ladder and sum the output to feed to your monophonic controller. I paraphrase here, but
surely it's liable to be a bit more complicated than this but that's the gist of it. I'm not a
service tech mind you but you would have a clean assembly but could destroy the Fatar if
you weren't careful. Again warranty void once you start soldering. Doepfer route is plug
and play no soldering but will require decoding midi to cv/gate/trigger.
Depends on what you want to put into it and what you expect out at jobs end, how much
DIY re-invention you undertake.
I have a pdf here but will forward directly to your address instead of further annoying the
group. Probably really an MFOS post if there is such a group mind you after all this text.
Best of luck
c~h
a
> awesome.
> Thanks Lance
> > Lance,
> mini
> keyboard
more
> > helpful.
> find
> > a
> keyboard?
> > i
> > > Thanks Lance Iden
> > assemblies
> > > for
> > > > use
> > > dissect
> > > > other
> > > > > Thanks Lance Iden
> make
> > a
> > > manuals
> 8x8
> > > switch
Re: keyboard
2008-12-06 by Dave Kendall
Hi.
I haven't tried this, but these docs might be of use. They show how to
convert an old casio keyboard for CV/gate use. The second is a
collection of notes from the old (now defunct) EFM forum.
Some EFM B.O.M.s had the odd wrong value - go by the schemo. They were
also designed for ±12V use, so if using ±15V, some parts may need
changing....
http://www.modular.fonik.de/files/EFMforum/orgEFMfiles/kbd2e.pdf
http://www.modular.fonik.de/files/EFMforum/KBD%202E%20forum.pdf
EFM is now not trading anymore, so no boards available, but the schemos
might be useful.
hope this helps, good luck :-)
cheers,
Dave
> assembly. Not
> you want is the
> common pitch bus.
> might think you
> cv/gate/trigger.
> jobs end, how much
> Best of luck
> c~h
> a
> schematic or a
> site would be
> > awesome.
> > Thanks Lance
> > > Lance,
> > mini
> mind you.
> keyboard assembly.
> any suitable "OEM"
> eclectic DIY touch
> > keyboard
> listening can be
> more
> > > helpful.
> > find
> > > a
> for a single buss
> > keyboard?
> > > i
> simplicities sake.
> > > > Thanks Lance Iden
> compatible keybaord
> > > assemblies
> > > > for
> > > > > use
> > > > dissect
> > > > > other
> > > > > > Thanks Lance Iden
> > make
> > > a
> site.
> > > > manuals
> they do have an
> > 8x8
> > > > switch
> what you need.
Re: keyboard
2008-12-07 by waynerdlance
Dave. thanks alot for this info. this is pretty much exactly what im looking for. all i can
really find available new are the diode matrix type keyboards and now i guess ill just have
to convert one.
thanks a bunch. Lance Iden
--- In cgs_synth@yahoogroups.com, Dave Kendall <davekendall@...> wrote:
> Hi.
> changing....
> might be useful.
> cheers,
> Dave
> > assembly. Not
> > you want is the
> > common pitch bus.
> > might think you
> > cv/gate/trigger.
> > jobs end, how much
> > Best of luck
> > c~h
> > a
> > schematic or a
> > site would be
> > > awesome.
> > > Thanks Lance
> > > > Lance,
> > > mini
> > mind you.
> > keyboard assembly.
> > any suitable "OEM"
> > eclectic DIY touch
> > > keyboard
> > listening can be
> > more
> > > > helpful.
> > > find
> > > > a
> > for a single buss
> > > keyboard?
> > > > i
> > simplicities sake.
> > > > > Thanks Lance Iden
> > compatible keybaord
> > > > assemblies
> > > > > for
> > > > > > use
> > > > > dissect
> > > > > > other
> > > > > > > Thanks Lance Iden
> > > make
> > > > a
> > site.
> > > > > manuals
> > they do have an
> > > 8x8
> > > > > switch
> > what you need.
