Royce,
You were right in saying "simple things are simple"...I have no clue what to do with that information...lol,
I think i should learn MIDI perhaps? Or is there a way to have the BC manager learn what i want it to do?
I have my BCR2000 set up with the Korg and on the page where the filter cutoff is located and I press learn while turning the first encoder, then i adjust the filter cutoff on the Korg and it says "Good" on the BCR2000, and it does change the cutoff on the Korg...But the values are 0 to 127 when they are supposed to be 0 to 99...I try to adjust the values but the BCR does not show them unless I select CC. I select CC and then I can adjust the minimum value and the maximum value and then the encoder works...until i try to program the encoder next to it...same procedure except when you turn one encoder they both turn...so I try too enter the parameter 271 in the par encoder (3rd encoder) but the values only go up to 127...am I at least headed in the right direction (for someone who does not know midi) to go, or do I really NEED a program like the BCmanager?
Maybe its just wishful thinking.
Let me know if you have any advice and tips to learn what i need to learn, I am going to use the BCR2000 just for synths like the Korg Prophecy.
Thanks in advance for any advice,
and if its time to learn midi, well...I hope I am up to the challenge.
David
On Thu, Feb 28, 2013 at 12:36 PM, Hobson David
<enarke01@...> wrote:
Royce,
Thank you for your reply and your assistance.
Much appreciated,
Thanks ,
David
On Wed, Feb 27, 2013 at 10:22 PM, David
Hello,
I have downloaded and tried to use "BC Manager" and came away more confused than when I started. I am, and let me make this clear, A TOTAL IDIOT when it comes to midi! I do not need another manual, I need some simple assitance. I am trying to map my first encoder (still) with the filter cutoff for my Korg Prophecy. The Korg Prophecy has two filters and i just need to map the first one for now, however, I do not know the parameter number for the cutoff which i believe is a nrpn (i don't even know what that means. I think if I have that parameter number i will be able to adjust the cutoff to my hearts desire. Can anyone give me assistance other than reading another manual?
When I have this figured out I will upload my templates fro the Prophecy and contribute to the software developers...
In short, I will be content.
Thanks in advance,
David
