Bc2000 (for the BCF2000 & BCR2000) group photo
Translate
Translate
2008-08-13 by manolo_k_
Hi.
I own a Bcf-2000 and i want to know if i can "translate" a input midi
controller on another controller sent to a Zoom Sampletrak.
This is because Roland Gr-1 sends the expression pedal as Controller
16 and i want to convert it on Controller 12 or 13. I cant use the Bcf
Expression Pedal entry cause is in use with another function.
Can the Bcf-2000 be used as a Midi translator for this?
Re: Translate
2008-08-13 by rpcfender
Hi
Not that I am aware of.
I guess you don't want to have a PC in the rig, but if that was OK you
could use MidiOx and set up a translation filter.
Royce
Re: Translate
2008-08-13 by ivaasura
--- In bc2000@yahoogroups.com, "manolo_k_" <manolo_k_@...> wrote:
> Hi.
Take a look at Bome's MIDI Translator...
http://www.bome.com/midi/translator/
