Bc2000 (for the BCF2000 & BCR2000) group photo
BCF2000 using SX3 - "GURU" help needed
2008-07-27 by nedaggg
Hi
Im new on using BCF , I bought a month ago . I trying to use Mackie
Control and I have few issues , hope you BC Gurus could help ( I use
Windows Vista ) !!  be patient my questions surely are pretty
basic ....
1) using Mackie Control Emulation , I have problems because it takes
lot of time to BCF to estabilize on the parameter that I just sent to
SX3 . If I press and select TRACK 01 , and then TRACK 02 using the
buttons on the top , it takes lots of time to led on the button to
light up , despite SX3 has perfectly changed to the TRACK 02
already . This is more annoying with the faders , if I change volume
on subsequent tracks , again SX3 responds well to the command , but
some moments after the fader comes back to previous position . Its
kinda weird .  Is there a way to set it up to avoid this ... ? The
funniest is SX3 receives all messages , but it seems BCF controls got
stuck on time . Im using a vista laptop , coreduo 1.7
2) I cannot select Insert or INstruments . Lets suppose I selected a
track where I have 02 inserts ( delay , compressor ) . I konw how to
go to the VIEW thats OK , I can see the panel with all the inserts
and send  , but how can I open those effects to be edited  ?
3) the same with Instruments , how can I open a Synth and how to edit
it ?  in MCE manual it says that the "learn" button + "bottom left
encoder group button" seems to be the combination , but I press it ,
after selected the track but nothing happens . Is there a way to make
the instrument to open , and then use the 08 push encoders to tweek
parameters ?
Is there any manual to use MCE ?
4) which working mode you BCF gurus think its best to use , MCE or
presets always ? I downloaded a mixer preset for Cubase that works
fine , so its better to work with this preset only for mixer , and
then to change preset to control Synths and Effects ?
5) the only problem I have is sometimes it freezes if coming back
from one preset to another . Lets suppose Im editing a Synth on
Preset 04 , then come back to Mixer preset 01 and then , zzzzzzz it
is freezed . Is it normal to happen ?
sorry the basic questions , hope someday I could contribute and not
only to ask for help
regards
DG
Re: [bc2000] BCF2000 using SX3 - "GURU" help needed
2008-07-28 by Ceedjay chez Free
Hi !
Do you speak French ? Or maybe you can understand it a bit ?
If yes, I wrote a big tutorial about using the BCF in MCE with Cubase (plus
other goodies, such as opening/closing plugin windows via MCE, which is
normally not possible), but did not get any time (and, unfortunately, won't
get any) to translate it into English.
It is in the files area on the BCx group, called BCF_2000.zip. There is also
a modified version of the viewer that I changed a bit so that it displays
the lane numbers.
If someone has some time and wants to translate this tutorial, please go
ahead ;o)
Cheers.
Jay
Re: BCF2000 using SX3 - "GURU" help needed
2008-07-28 by k5kip_1999
Will the viewer work with bcr2000?
I have tried with no success.
Kip
--- In bc2000@yahoogroups.com, "Ceedjay chez Free" <cubaseisbest@...>
wrote:
> Hi !
Cubase (plus
is also
displays
> the lane numbers.
please go
> ahead ;o)
> Cheers.
> Jay
Re: [bc2000] Re: BCF2000 using SX3 - "GURU" help needed
Hi !
No it won't. It was designed for use with the BCF in emu mode. As there was
no emu mode planned for the BCR.....
Cheers.
Jay
k5kip_1999 <k5kip_1999@...> a \ufffdcrit:
> Kip
