Bc2000 (for the BCF2000 & BCR2000) group photo
(no subject)
(no subject)
2008-07-06 by slobodan djordjevic
Hi i have question about to connect MIDI keyboard to BCR with midi cable, than BCR to BCF with MIDI cable, and than BCF to comp with usb?
Or i find that i connect with USB hub? What i need for that, i mean on soft?
Sorry for bad English
BCR BCF Connection
2008-07-07 by rpcfender
--- In bc2000@yahoogroups.com, slobodan djordjevic
<djordjevic_sloba@...> wrote:
Hi Slobodan,
So...
Keyboard --- via MIDI ---> BCR ---- via MIDI ---> BCF ---via USB--->
Computer
Is this correct?
Page 10 of the user manual shows you how to do this.
Down load the latest version of the manual (version 1.1 in various
languages) from the www.behringer.com
on soft?
I'm not quite sure what you mean here.
You only need a USB hub if you are short of USB ports on you PC
Hope this helps
Royce
Re: BCR BCF Connection
2008-07-07 by djordjevic_sloba
> Computer
> Is this correct?
Ok this is i need. On manuel it is pic that are connected bcr and bcf
no keyboard. But if i connect keyboard in MIDI IN on BCR, i shudent
have a problem, do i?
> <djordjevic_sloba@> wrote:
> Hi Slobodan,
midi
usb?
> So...
> Computer
> Is this correct?
mean
> on soft?
> Hope this helps
> Royce
> > Computer
> > Is this correct?
The picture shows a lead going from the BCF MidiOut to the BCR MidiIn
Midi messages sent from the PC program CAN be used to change the red
display ring around the encoders (on both the BCF and BCR) and so
there needs to be a path back from the PC -> BCF -> BCR
If it is OK to not to have this feature then select mode S-1 on the
BCR and connect the keyboard into the BCR MidiIn.
S-1 mode will merge the data from the Keyboard and the BCR and output
it to the MidiOut on the BCR
Keyboard->
          |-> BCF -> PC
BCR------>     ^      |
All the best
Royce
What is this?
> Keyboard->
>           |-> BCF -> PC
> BCR------>     ^      |
OK for S-1 mod, i realy dont need for LED rings.
And if i use USB hub, is there be latence for that tipe connection?
Do i need Asio drivers?
USB---
> > > Computer
> > > Is this correct?
bcf
shudent
MidiIn
output
> Keyboard->
>           |-> BCF -> PC
> BCR------>     ^      |
> All the best
> Royce
--- In bc2000@yahoogroups.com, "djordjevic_sloba"
> What is this?
> > Keyboard->
> >           |-> BCF -> PC
> > BCR------>     ^      |
Just showing the flow of the Midi messages
I think you are thinking about audio. So no you don't.
The BCF/BCR are Midi devices and there shouldn't be any noticeable latency
Royce
