Re: Cirklon+tb
2013-02-20 by Lorne Hammond
Index last updated: 2026-04-28 23:15 UTC
That should work, but while this sounds like heresy the cyclonix 303 clone is better, it speaks and sends midi in native format. Lorne in Canada [Non-text portions of this message have been removed]
2013-02-21 by Colin Fraser
> That should work, but while this sounds like heresy the > cyclonix 303 clone is better, it speaks and sends midi in > native format. Lorne in Canada An original 303 equipped with a Sequentix MIDIBass 303 MIDI retrofit also sends and receives native MIDI, and was primarily designed to capture the outputs from a 303 into a P3 pattern. So obviously that would be my recommendation :-) http://www.sequentix.com/sq_mb303.htm I tend to write my 303 patterns directly in Cirklon now, but I'll try to make a video to show how the internal 303 patterns can be captured with realtime record for playback and further editing. With a two-way MIDI connection between a MIDIBassed 303 and a P3 or Cirklon, it's a very simple process. Best regards, Colin Fraser Sequentix Music Systems Ltd http://www.sequentix.com
2013-02-21 by dario
Hi Colin. thank you for your answer. there is no choice for a man who loves his instruments. I think i'll take the midibass in the future.. thanks a lot --- In analogue-sequencer@yahoogroups.com, "Colin Fraser" <colin@...> wrote:
> > > > That should work, but while this sounds like heresy the > > cyclonix 303 clone is better, it speaks and sends midi in > > native format. Lorne in Canada > > An original 303 equipped with a Sequentix MIDIBass 303 MIDI retrofit also > sends and receives native MIDI, and was primarily designed to capture the > outputs from a 303 into a P3 pattern. > So obviously that would be my recommendation :-) > > http://www.sequentix.com/sq_mb303.htm > > I tend to write my 303 patterns directly in Cirklon now, but I'll try to > make a video to show how the internal 303 patterns can be captured with > realtime record for playback and further editing. > With a two-way MIDI connection between a MIDIBassed 303 and a P3 or Cirklon, > it's a very simple process. > > > Best regards, > Colin Fraser > Sequentix Music Systems Ltd > http://www.sequentix.com >
