Analogue-sequencer
Index last updated: 2026-04-28 23:15 UTC
Re: P3 issue- please help...
2012-10-24 by Lorne Hammond
That was my point, you can only send 8 tracks on the midi ports.  Nemo gives
you two independent midi buses with 2 jacks each, the P3 has I think one bus
with four jacks and din sync.
The original inquiry is about why he can't send out 16 tracks, or the ones
9-16, after using 1-8.  I often set a K2000 to global receive and use it to
bend and slur everything in an orchestral setting.
Lorne
2012-10-31 by duncan
well, without wanting to be rude about it, this is from the *manual*:
"P3 is a pattern-based, 8 track hardware MIDI sequencer."
that might go some way to explaining why "tracks" 9-16 don't seem to be transmitting midi data!
I often use my two P3s on the higher numbered channels without difficulty, & use a midi router to take care of filtering &c.
but I haven't managed to get more than 8 tracks playing at once except by using them both at the same time. :-)
duncan.
--- In analogue-sequencer@yahoogroups.com, "Lorne Hammond" <lhammond@...> wrote:
> Lorne
